Got the bay done yesterday after work! Not a fun job pulling the loom out with everything still attached... Car's almost ready to go to painter now. I want to weld up the stock intercooler holes so we have no drama drilling new one later. Ideally I'd like to get motor in with manifolds and turbo on and mock up piping and cut holes etc and then get it painted. Will see what happens though.
Need to degrease the bay and give it a good clean with the gurney. My powersteering has been leaking for a while so its covered in oil..
  • Like 2
So she went off to the painter on Wednesday. Should be ready mid next week ? start putting all the stuff back into the bay and get the loom all cleaned up ready to go.
Ordered plazmaman 100mm intercooler, 72mm throttlebody and flange to weld onto the greddy intake and a few 3" plazmaclamps. Hopefully be here in the next few weeks and start mounting it up.
  • Like 3
Car came back today! Super happy with how it turned out! Makes me wanna respray the whole thing ?
Got a few things back in today, auto brake pedal, booster and throttle cable all done so rest of it is engine bay work now. Tomorrow I'll plumb the A/C, bring wiring harness back through the guard and put the headlights back in.
  • Like 1
Progress is happening slowly. Got almost everything back in the bay now. Decided I'm going to delete the fuse box and make it look nice somehow. Also put in a new universal washerbottle instead of the hideously massive stock item. Heres the car as she sits.
Pulled the loom apart to add/remove anything we wont be using, going to give it a makeover with some nice sleeving and reroute wiring into the guards to keep it looking clean! Few more wires and stuff to add for additional sensors and thing then start depinning and sleeving it all! Should be a fun time.... not!
RIPSNZ sump is on the way, should be here this week/early next week! Thing looks nice ? Can't wait to bolt it all up!
Last but not least new pistons! Couple bores were a bit out of wack so stepping it up to a 86.5 9:1CR. Should bump it up nicely from the 8.5:1 pistons that were in it. Dropped them off at machinist tonight, rotating assemblys off to balancer this week and the blocks going for a bore and acid dip to clean it up nicely ? Should only be a couple weeks away now!
  • Like 3
  • 3 weeks later...
So been working on the wiring harness the last few weeks. Im pretty happy with how it turned out for what it is. I think id rather do a brand new loom then resleeve a stock one again ?
In the go fast department motor is almost due back! Head will be finished this week coming and block should be the week after. Got bored and honed for new pistons last week and balanced rotating assembly this week. Waiting on spool to get more L19 rod bolts back in stock so we can get rod bearing clearances set.
  • Like 2
Rod bolts and bearings ordered yesterday, engine builder is really busy atm and said should be all done by end of next week :) Also dropped my sump down to be painted black which should be ready in a couple of days.
I pulled my fuel pump out of the tank then decided to get a surge tank instead of modifying the stock hat. Ordered an AI SP1200. Will make it a lot easier if i have to put a 3rd pump in if we need more fuel. I'll be running hardline in boot and remove the factory lines to run twin 1/2" hardlines to engine bay then split the feed to twin -6 to feed the rail. Using these billet clamps to fix it to the body should look nice and semi stock.
Wiring is coming along pretty good! Finished sleeving the lot then forgot to bring the wires down for the crank trigger so ill have to pull it apart and do that then thats its for the loom! I hope... i didnt like the look of just heatshrink for finished product so got sum sleeving and came up 10x better! Looks a lot nicer now.
  • Like 1
Yeah shes a big one hahah! It was making 910whp on a 2.8 GTR. Should get pretty close to my goal I think :D
Since the turbos black already I'm going to f**k the polished intake off and go black as well. Should come up nice ?
  • Like 1
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
