Got a package yesterday, was expecting it to be my surge tank but this rocked up instead!! 4 months and the wait is up. I should have ordered front runners at the same time but oh well :(
Should look secs with mickeys wrapped around them and mounted ?
Finally loom is all complete now! Hopefully when everything is in it all works... Come up pretty good. It's back in the car with all the stock connectors on.
Also started to fiddling around where to mount my boost solenoid and FPR. Was thinking about mounting it there but decided to keep it hidden as best we can so hopefully mount it under the catch can somewhere.
Should have some more goodies arriving this week as well! 6boost, surge tank, head and the bottom end :D
  • Like 4
Thanks mate!
Surge tank and hardline turned up as well! Nice bit of gear. Tank is going back as it had a bits that were damaged during anodizing so they're upgrading me to an SPR1200 ?
Wasted no time getting the pumps in, not that I'll be able to use them yet...
Need to start ripping out my stock fuel lines that will be replaced with 1/2" -8 hardline. Will be -8 to the bay splitting to -6 into the rail then -8 to the fpr and back go surge.
  • Like 1
Little bit of progress on her last week. Ripped the stock fuel lines out to make way for the new -8 hardline. Need to make something to hold the brake line in place as well.
Few of my sensors arrived. 5bar MAP sensor, and oil and fuel pressure sensors. Also ordered a new IAT sensor, oil temp sensor, Link CAN Lambda and Billet Coil Kit 2000hp R35 kit.
Engine builder sent a few snaps to me today! Ready for assembly now wooo! Rings are all gapped, just gotta drop down the old pump housing so he can machine out the slot for the crank trigger, and take new crank seal and pump gasket and it's going together.
NSFW ;)
  • Like 7
Spent a few hours on it this morning and painted the block. Came up alright, few hard to get spots around the deck that I missed cause I didnt want to get paint on/inside.
Fitted up my crank trigger as well. Thinking going for a 12t on there instead of the 6t.
Went to put the sump on but didn't have any pickup o rings left so ordered that, rear main, cam seals and rocker cover seals as well. Hopefully next couple days ill have the short block all bolted together.
Edited by klutched
  • Like 4
Have had the inlaws up for the last couple weeks so nothing has really been done on her. Went down and picked up a new set of MTs. Can't wait to get em fitted up and see how they sit in the guards. Also finished mounting the surge tank, relays are mounted so will finish wiring them up sometime this week.
We also decided to go to a 26 head, it's getting built atm and going to contain a full race port, ferrea valves, kelford springs, cut seats and a service. Hopefully should be done early next month.
Had a couple hours spare today so wired up the surge tank. Just gotta find my split coro to clean it all up and get some smaller lugs for the pos and neg on the tank. Also gotta get the factory pump trigger over to relays.
Popped down to the shop after work today and slapped my sump on. Bottom ends ready to roll now.
Stole a couple of crimps while I was down there and got the surge tank 90% sorted. Gotta pull the 3rd line out and put a bung in then she can get bolted in and not come out... Until we need more fuel ?
  • Like 1
Got the mickeys fitted up today anddd they fit mint. Can't wait to go out and get some heat into em.
Also finished putting my intank pump back in lastnight and today finished off the surge. Time to buy all my fittings and lines and plumb it up :D
  • Like 2
5 hours ago, azzada1 said:
what size and back space are those welds? And how much clearance do you have on the rear brakes? looks great with the 27" (27.5) radial!
Theyre a 15x8 6.5 bs. Its got a 10mm spacer on it which isn't ideal but I had to space it off the brakes (only need 3mm but wanted a little more). If i was gonna do it again i'd get 15x8 6"bs. Would push it out to around where mine sit now. Wish I could slam a 275/60 under it :(
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
