I have been a member of this site for quite a while (2005, sweet Jesus), some cars ago I abused a 230rwkw (Racepace tuned) AUTO R33 S1.5 GTS-T - good times.
The Sour Kraut
About 13 months ago I hunted down and purchased what I thought was a good example of an AUDI A8 D3 4.2 Quattro with only 103000km. In my defense I was under time pressure after my previous car was written off. I had looked at some others, D2s were all thrashed out and other D3s had S8 badges and dodgy fixes or were very over priced. I had done quite a bit of research, knew the common faults, picked up a VAG-COM and was confident that should some of these common issues arise I could handle them. Instead I learnt a lessen in German over-engineering. You see, most Euro cars seem to be like onions in that each system and subsystem is layered on top of each other and other unrelated systems. The more layers you have to peel back to even inspect something the more you cry and or cry about paying labour for.
I had had the car inspected in QLD (never buy interstate if you can't inspect personally - first lesson) and it came back with a near clean bill of health bar the A/C heater valves, a common VAG issue.
The whole heater valve box was changed out prior to the car being shipped down. A/C didn't work properly after I picked up the car - which was entirely due to the retarded monkey that replaced the heater valves. Pinched wires had damaged the loom, all the tabs were broken off the unit and it was glued in, ECU covers were broken or missing (layers). Jeremy Clarkson with a hammer could have done a better job. Ended up just bridging the passenger valve to the driver controls as after the dash was out and half the engine bay still couldn't find every break.
Car came with a single key - never buy a car with a single key (no shit guy), especially a euro. $700 later I had a spare.
MMI screen struggled to move from closed to open - extremely common issue due to the weak as piss plastic gears. Picked up replacement metal gears and never got around to installing them. Taking more of the dash out for something that mostly worked did not appeal.
The auto boot could not auto itself without some help, another common fault which was resolved with an uprated motor in later years.
Water would pool inside the boot lid. Actually a common fault due to inexplicably poor workmanship on the boot lid construction where gaps could be left in seams behind the tail lights in the boot lid. Solved with any all purpose sealant.
Starter motor would almost randomly say f**k you and the car would not start. Not really a "common" fault but the more you look into it the more common you realize it is. The car would start every time - as long as the battery was near 100% so it had the juice to kick the starter in the guts.
Battery was not being charged enough. I would have to charge the battery every one-two weeks so the car would start consistently. The alternator in these is water cooled because f**k you that's why. The battery was also enormous, the same unit that goes into a Porsche Cayenne which I lucked out and picked one up at cost price from Battery World, naturally the battery had partially collapsed en route to Melbourne, required two truck batteries to get started when it arrived off the train.
Front suspension collapsed. This is a common fault for all cars that use air struts which is a list of very expensive and never kept past warranty cars. Replaced the lot with DGR coilovers from Otaku Garage - surprisingly good. Put the fronts in myself because when they go the front is very very low, not Tesla on the ground low but close enough that driving or getting a tow were pretty much out of the question.
Engine was misfiring, never got around to fully investigating, suspected it needed a new valve cover gasket, happens to the V10s a fair bit and can on the V8s. Oil gets into the spark plug tube and fouls the plug.
ZF 6 speed would "hoot" and sometimes hunt a bit when in slow but not quite stop start traffic. There is actually a service bulletin for this not that Penfold AUDI had any idea. Picked up the filter and gasket from the US because Australia still believes the lifetime fluid lie, never got to changing over the filter and fluid.
Firmware was all original versions and should have been updated by AUDI when it was serviced. Couldn't find the interim version I needed to then update to the latest firmware. Penfold AUDI told me not to get them to do it and to download the discs myself instead.
The thing that really killed it was the leaks. After a weekend away I came back to a drivers footwell full of water. The sunroof drains had blocked and some water had got in that way but if the volume that was in the footwell had come in through the roof the car would have been a write-off, there are tales of this on VAG related forums because again an inexplicably shit design for something has managed to exist for 20+ years and water pours all over the MMI controls and gets into the loom which you'll be quoted near $20,000 to replace. Near impossible to clean out and requiring many layers to come off to do anything about. The rest of the water must have come in the AC vents. Two causes for this, weather guard at the top if the bonnet missing or the plenum drains are blocked. Easy check right? Just jump under the car and inspect? NOPE. The correct procedure to check the inexplicably crimped plenum drains is to remove the engine and gearbox. FU AUDI, FU.
Even with all that and I have likely forgot many more issues, the A8 was a brilliant car to drive, even better with the coilovers.
So it was with equal measure frustration and regret that I began the search for a different car and different I found.
The Swede
For some reason I was drawn to something opposite, much smaller (A8 is ~5.2m long and that's the SWB) with less stuff but still comfortable and with...something. It had to have something about it and not just be a snoozefest A-B all the time. Some people don't get that at all. "Why don't you buy something common?" indeed, why buy clothes when I could wear a hessian sack? Why live in a house when I could gut a horse and crawl inside?
My search criteria kept turning up a lot of cheap shit which was of no interest to me but interspersed in all the crap I kept seeing Saab and Volvo. The 9-3, 9-5, S40 and S60 grew on me as I hunted around. A turbo-X would have been nice but they are extremely rare in Australia and about $30k which was a bit more than I wanted to spend. My first child is about to arrive too so part of the criteria was fairly cheap and cheaper to run. My biggest issue ended up being I needed to trade in the A8 which limited my options quite drastically, mostly because there was no way I would sell a car I knew was about to implode to a person instead of an entity of the same type that screwed me in the first place.
If I could have bought private I would likely be in a 9-3. Instead I found a nice little S40 D5 the "performance" diesel. It's not optioned up apart from being a D5 but it's clean and comfortable and based on a pretty great platform that it shares with the Focus and Mazda 3. Some idiot put OptiLife tyres on it which is great if you hate grip because they are totally inadequate in a FWD car with over 400nm of torque. But still the car has been great fun so far.
The BMW attached to the dealer I bought the S40 at was supposed to perform a minor service - but being a dealer instead they topped off the oil and probably did nothing else. Being the ignorant twats they are they did not realize this would cause a DTC due to the oil level being too high as most dealers will put 6L into a D5 engine when it should have at most 5.8L (5.5 recommended). It says so on a sticker under the bonnet... How hard can it be. I extracted the extra oil.
So now after much oil specification research and finding the right stock I'll be changing the oil and the ATF this long weekend. Recently managed an easy 680KM for under $50 which is fine by me. The S40 goes really well but would go even better if it wasn't strangled by Euro IV emissions gear which it could have been sold here legally without but now that it's on I definitely won't be tampering with the DPF...
There is not a whole lot that I want to change with the S40 which is probably a good thing. The adventure continues.
TL;DR
Common problems are common.
Used car salesman are dicks.
If you can't run a diagnostic scan on a euro yourself and it's out of warranty you probably shouldn't buy it.
I drive a Swedish tractor.
That was cathartic.
  • Like 5
I always wondered who bought second hand euro's......I think you should try a Peugeot or Fiat next!!!
Actually, no, don't.........be cheaper to find a brick wall and start hitting your head against it :woot:
Alfa or Lada.
  • 3 weeks later...
  • 1 month later...
That's the older model. Being that low would be a pretty big hazard to the sump with a i5 diesel
Seems to be decent quality inside and out. A bit bland but not quite at the old turbo brick levels.
Front bushes are completely shot, another fail item for Valley BMW mechanics. Now to pick a kit and if I replace them all anyway with something from SuperPro or Whiteline
I was seriously considering a Volvo wagon less than $10,000. Ended up getting a Pooparu as the Volvos were too expensive for me. At least they have some decent resale value.
I too considered a Volvo wagon but somehow ended up with an m35 stagea. Almost a Volvo[emoji3]
When our vrx Outlander was written off near 18months ago, we bought a (well) used XC90. 1 owner, always serviced at the dealer who sold it. Nearly 230,000kms on it now and it has been awesome. So much so I think we will have Volvo's as the family cars for years to come.
Haven't had to fix anything on it yet however.
  • 6 months later...
I did end up getting new bushes for the front end. Whiteline kit including their P1 platform "anti-lift" kit.
Much better drive now, even better that I managed to get the Whiteline bushes for wholesale direct from Whiteline.
I do miss the driving feel of the A8 though, more leathery goodness and effortless power.
The undertray had enough and detached itself from it's front mount points while driving - exciting times. Completely due to the shitty nylon stoppers and deep thread (what's the right word for that?) screws they use in conjunction with dirt roads. Just got chunkier screws for now, a temp fix and then I'll get a more robust aluminium or steel plate made up.
Edited by DivHunter
  • 11 months later...
How did I miss this thread?
Some of your A8 problems made their way into my mkiv Bora and our old B6 Passat. Most notably the stupid sunroof drains. Within weeks of owning the Passat we had a new airbag controller en route from Germany. I found all the drains and snipped off the pinched ends.
I love Swedish also. You need to post pics of both cars. I'm a sucka for a big German.
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
