http://www.crawfordaustralia.com/
lol x10..
come on, tricking the MAF so your car gets more economy & power? Newer cars run wideband o2 feedback.. all this shit will do it throw a CEL when there's too much correction going on. Why on earth do people fall for this junk for a car that's worth tens of thousands of dollars.
Trying my hardest not to say anything negative, but they're pushing their products all over car groups and people are gobbling it up.
https://www.sau.com.au/forums/topic/465041-maf-spacers-what-a-joke/
I love that they are a 'genuine performance part' - just like genuine apple style iPhones. You can stick genuine in front of almost anything.
I wonder if you can stack them for double the improvements??
Stackable spacers! Brilliant! Mount the MAF in the boot!
  • Like 1
F! If I didn't have this crap map sensor I could make all kinds of gains.
I'm going to put a spacer on the bell housing to trick the gearbox into thinking there's 1000hp from the motor.
Wouldn't the box just break?
Na there's nothing but benefits from the spacer, Nissan left 20% on the table & the thickness has been calculated over 35 years of winning, also the more you thrash it the better it is
Brilliant! These guys are genuises!
Just mount maf to the roof. That way the fueling is based on air flow/road speed. Imagine the fuel savings in stop start traffic.
oooooh is that how those new fancy cars work when they turn off at red lights? they're just stalling.. makes sense
  • Like 2
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
