  • 3 weeks later...
I'lll post up my -5 result later when Photobucket is back up (in my showcase below if I forget), but Ambi3nce's -9 result looks very similar to my -5 result.
Main difference looks to be power band is on 300-500rpm sooner, and ~15% more peak torque ! (520 vs 605)
Same boost, same peak power, same ecu, same cams, same fuel, same workshop, same tuner/dyno.
...not sure if you could get much closer in terms of setup for comparison?
Headstuds & more boost should widen the gap between -5 & -9s in the top end though.
  • 1 month later...
Hi folks, Skyline newbie here, so please pardon my obviously elementary question.
I was under the impression that -9's are smallest of the bunch, smaller than -7's.  Is that incorrect?  Because I ask the vendor to quote me quickest responding/spooling Garret turbo, and he told me that's -9's.
Edited by TXSquirrel
28 minutes ago, r32-25t said:
Yes that's correct but the -7 and -9 flow pretty much the same power
I'm okay if -9's flow less power than -7's, but if -9's are more responsive then I will stick with -9's.
So with -9's on stock 440cc injectors, can I run 16psi?  I believe 16psi is the base setting for Garrett actuators.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
