Engine/Car: rb26dett / r32 gtr
Type of failure: 141klm on the motor - head warped and cracked. block cracked between head bolts and oil galleries.
Factors influencing the failure: radiator failed on the race track. cooked the motor real good
State of tune of the engine: standard, being run in
Suspension and tyres: n/a
Oil used and service interval: never made it off the first oil change
General comments: don't always assume stuff from china is crap and doesn't fit. sometimes it would fit perfectly if you got the right part in the right box
lol kel is nowhere it is 2 to 4. but i seem to have a knack for finding creative ways to kill them. new one is in and ready to run next weekend. but we don't have a psare motor for the year now
  • 3 weeks later...
Engine/Car: 1990 r32 gtr
Type of failure: number 6 piston broken
Factors influencing the failure: Not sure, probably too much power for std engine.
State of tune of the engine: 307rwkw on 90k unopened motor (18psi) on HKS GT-SS turbos
Suspension and tyres: bilstein with eibach springs
Oil used and service interval: Redline Oil 10W-40, Just serviced
General comments: Car was completely stock before tune. Signs of neglect due to thick gungy oil found in stock turbos, motor may have been weakened over time and the extra power tipped it over the edge.
  • 3 months later...
Engine/Car:
RB20 A31 cefiro
Type of failure: broken ringlands on piston #3 and #1...
possible valve seals on god knows what pistons.. oil mania
holding a 3rd gear slide at mallala with the full face helmet and experiencing my first taste of detonation
State of tune of the engine: 3 inch turbo to tip zorst no cat no mufflers, pod, r34 smic, bleed valve set at 13psi.
Suspension and tyres: full tein s13 coil overs, random treads
Oil used and service interval: mobil 1 10w50 i think
General comments: warmish day at mallala.. bit to excited with my first time on the track..
bets fun of my life sliding while not worrying about police..
now that motor is f**ked.. 70% threw rb25/30 build :banana:
yeeooww
  • 1 month later...
Oh good point I have missed one:
Type of failure: 600 klm and 1.5 race meets this time
Factors influencing the failure: the crack in the oil gallery in the block might have led to low oil pressure. In turn 1 at Eastern Creek. At 8,200 revs. Oops. Oil pressure was never high enough in that motor and got worse when it was hot.
State of tune of the engine: standard except for cam gears and computer.
Suspension and tyres: bilsteins, yoko a048r. It was pulling good gs at the time :cool:
Oil used and service interval: well it was only 600klm old so I hadn't moved off the run in oil - penzoil 10w50 mineral oil. changed 3 times in 600klm
General comments: hmmm...when I say "check the block out" to a machine shop, I mean it. On the bright side they paid for the new motor which to be fair is all (or more) than you could ever expect. especially since it died on the race track.
Engine/Car/Year/K's: RB26 GTR33 96 140K
Type of failure: Bent crank
Factors influencing the failure: Age and pushing stock bottom end.May have been unbalanced for a long time.
State of tune of the engine: 290AWKW,s,-5 Turbo's,Poncams,700cc injectors,PFC,AVCR always set at 1.1Bar.
Bottom end: Stock
Suspension and tyres: Ohlins ,K104 Ventus
Service intervals: 5k to 7K
Always was worried about the bottom end when pushing higher numbers.
This happend 12 months ago but any way:
Engine/Car:R33 RB25DET
Type of failure: Snapped conrod on 1st piston, smashed piston 1 into metal shavings, punched holes in the cylender walls.
Factors influencing the failure: Engine had a long and hard life.
State of tune of the engine: SAFCII tuned 220RWKW, 18psi.....
Suspension and tyres: big ones...
Oil used and service interval: HPR15, every 5000km
General comments: Pulled the engine down and it was a huge mess.... other conrods looked like they had hairline fractures aswell... RB25DETs dont have the strongest conrods.
Edited by Finny
I never thought i would be posting in here but here i go:
Engine/Car:RB25DET
Type of failure: Smashed pistons and valve train
Factors influencing the failure: Timing belt too tight and was not checked. Snapped the idler pulley shaft.
CP pistons(9.0:1CR) 20thou over
Spool rods
Cometic 1.2mm MLS head gasket
Nissan gasket kit
Tomei valve springs
Tomei 256 Poncams
Tomei oil gallery restrictor
JUN crank collar
Custom head to sump oil drain
N1 oil pump
Greddy plenum
Greddy throttle adapter
Nismo 740c injectors
Nismo fuel pump
Nismo engine mounts
ARP head,main,rod and exhaust studs
ACL Race series main and rod bearings
Splitfire coils
GT3037 .82 turbo (has the slotted cover for that T51r sound)
GCG Stainless highmount manifold
Turbosmart 38mm Ultragate
All controlled by a Haltech E11v2.
Suspension and tyres: Stock suspension, sitting on 19s.
Oil used and service interval: Motul Turbolite 4100
General comments: Engine was running excellent and produced easy power with no stress. Just sucks that a cheap and overlooked part caused this big mess.
Engine is currently being rebuilt with new pistons, all new valve train ect ect
Engine/Car:R33 RB25DET engine 1
Type of failure: clutch kicked 3rd, snapped engine mount, engine lifted, ripped off boost controller, free boosted smashed 3 pistons
Factors influencing the failure: too shorter hose on boost controller!!!
State of tune of the engine: SAFCII tuned to 172 rwkw
Engine/Car:R33 RB25DET Engine 2
Type of failure: 0 compression on 6
Factors influencing the failure: throttle stuck open, couldnt unstick had to turn off car, everything up the shit trying to turn corner..bad scenario.
State of tune of the engine: stockie wrecker engine, std computer
Third time lucky...so they say...
  • 3 weeks later...
This has been Heart and Wallet breaking. :)
GET RID OF YOUR CERAMIC TURBOS (especially if running higher boost).
Engine/Car: 1993 R32 GTR
Type of failure: Ceramic turbine failure leading to ceramic dust being blown through the engine (all cylinders have some dust), knackered rings, scratched/gouged bores and ceramic dust crushed into quench zone in cylinders 4,5 and 6. That's right, the block, pistons, rings and head are all damaged as well as one dead turbo.
Factors influencing the failure: Ceramic turbos well past their 'service'/replacement date. NO EXTRA BOOST (in my ownership at least)
State of tune of the engine: Dead stock standard engine. Highflow cat, kiakamoto 3.5inch exhaust, pipercross filter. Nothing special.
Suspension and tyres: Irrelevent.
Oil used and service interval: Mobil 1 every 5000km religiously.
General comments: An especially painful turbo/engine failure necessitating a full rebuit and new turbos, very expensive. My advice: don't run higher than 13psi on stock turbo's as this is the service limit according to the workshop manual. Also 'service' or replace at the 100,000 interval. I ran stock boost specifically to avoid this kind of failure but it still happened. Just get rid of the ceramic turbos if you can.
It should also be noted that my oil pump drive showed signs of significant wear... :O
Engine/Car: 1994 R33 GTST with R32 RB26
Type of failure: Broken ring land and slight meltage of No6 piston
Factors influencing the failure: Revving to 8000rpm and a 32deg day lol
State of tune of the engine: Trust 3.5in full exhaust, Djetro, FMIC, 11psi and 245rwkw and 610Nm of torque
Suspension and tyres: Cusco Camber, toe and castor rods, G4 Coilovers
Oil used and service interval: Motul Turbolight 4100 (3000km)
General comments: Every day for about a year or so, revving hard for drifting, drag and circuit, she finally cried enough. Was doing 12.89 at 114mph with shithouse 2.4sec 60ft times haha 3rd run of the day and away she went. Did sound good hitting 8000rpm limiter though :banana:
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
