3 hours ago, Cowboy1600 said:
I'm not saying don't bother with alarms and immobilisers, what I'm saying is in the grand scheme of things they do f**k all.  But you never know, you might get lucky.
Nope with a determined thief who has weighed the risks and understands alarm systems.. for the most part nope they wont do anything.
Spend the money on the install rather than the hardware and it might be a different story. Like have the installer pull out the dash and install it behind there, rather than cable tied to the steering column like most systems. Have them use factory relays, kill switches, piezo sirens inside the car. There are many ways to skin a cat.
At the end of the day they can always tow truck your car away, but that's pretty rare compared to opportunity thefts, and that's what we should be paying our installer to prevent.
Car has just been recovered. The cops spotted the car around Mt Waverley and chased it down. The pricks tried to get it on the freeway, but got stuck on the corner of Huntingdale Rd & Waverley Rd due to oncoming traffic, so they ditched the car and did a runner.
At the holding yard now getting dusted for finger prints, so with any luck it should be out in about 48hrs.
Will line up the boys @ Racepace to give it a once over.
Thanks to everyone who helped with the spotting...very much appreciated.
Pics of car as it was getting offloaded (was lucky I got to the holding yard just as they were offloading it)
57a88709a22da_ImageUploadedBySAUCommunit57a88737f288a_ImageUploadedBySAUCommunit
From the quick look I had on the outside all I can see it the rims are badly kerbed...but if that's all that is damaged I will be over the moon.
  • Like 12
curious: what happens to insurance if the car is recovered, but deemed undamaged? do you still make a claim (for eg) to replace the wheels? what about costs in getting the car inspected for potential engine or drivetrain damage?
You can pay an excess and proceed with a claim and such costs will be covered by insurance. I'm guessing a set of 33R (?) rims won't be worth the excess though, unless the car has mechanical damage.
Dumb f**ks obviously can't even park / drive. Not that I expected much from car thieves.
Yeah...birds is spot on.
Because I was with RACV on there classic insurance the excess is only $300 :-)
Curious now to see how well it stood up the being trashed 24/7 for two days...LOL.
Being jap cars, probably faired better than most stolen cars. However, in my experience, if not stealing for parts, they steal these cars to thrash them and them burn/dump them once broken :(
There was a recovered R34 sitting in my mechanic's workshop and the bonnet had a massive heat patch on it. Coilpacks were cooked. I'd definitely get the engine checked for compression etc.
So engine is toast, because I was running E85 and as a result I ran a bit of timing on it...dumb pricks put 98 in it and because I only have a Power FC, it's not smart enough to pull timing out (also found out the managed 1200kms in 2 days).
Transmission is also gone (the guys at Racepace only put the new box in a few months back)...the must have been flat shifting and all, and being still on run-in oil, I don't think it liked it.
Apart from that, and a few small cosmetic issues aside, it doesn't look to bad.
The engine going, i aren't to sad about it, as the previous build on it was built with 274 cams, so it really didn't start to move till it revved past 5k...insurance should cover me for a standard build then I will top up what's required for a RP build (previous car was built by Benno, so can't speak highly enough of there builds), which I am happy with.
Everything else that's required to be fixed on the car though, I would be expecting insurance to cover me...should get the final word on this tomorrow.
  • Like 2
Glad they found your car mate, bloody low life scumbags.
Get a GPS tracking system installed!  Carzon in Dandenong is good. Track LIVE 24/7 via phone app. $15 per month under $500 to install.
  • 3 months later...
Any update on your car? I saw your car while mine was being prepped for roadworthy, and then once it had been broken into... Did you take it home in time for Christmas?
Any update on your car? I saw your car while mine was being prepped for roadworthy, and then once it had been broken into... Did you take yours home in time for Christmas?
Yeah...got it back just before they Xmas break.
Just to make sure this doesn't happen again, ended up fitting a decent alarm and a tracker as well.
Insurance paid for a standard build so I bit the bullet and paid the difference for a few goodies while they had it open (rb28, diff, etc).
Been meaning to start a build thread in the project section, so will try to get that done in the next couple of days.
Pic of how it turned up, after I picked it up from the detailer...very happy with how it turned out (the detailing part, not the stolen part...lol)
IMG_1483284092.690527.jpg.e78e364a48d474
  • Like 1
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
