Been a long time lurker here but just joined recently just to get some thoughts & opinions.
So I'm currently in a long-standing dilemma, whether should I build an r32 with a jzx90 1jzgte or just get a toyota jzx100 chaser which has a newer engine. Main purpose will be a reliable daily and will have occasional track/drift days.
If you had the time and money, what would you rather pick between the 2?
Also has anyone done an r32 1jz here? What are your thoughts?
https://www.sau.com.au/forums/topic/466306-r32-1jz-or-jzx100-chaser/
2 hours ago, Cowboy1600 said:
Is it school holidays already?
That necessary?
I have no opinion on this. I do love cool conversions though. I reckon a nice R32 with a 1JZ might be cheaper than a JZX100.
  • Like 1
Wow thank you for all the responses guys ?
Ok, i guess the only unicorn is my daily beater honda hahaha. 1jz does sounds phenomenal.
Have already spoken to a few wreckers and only 1 is available to ship a bunch of jzx90/100 halfcuts, big nom noms!
Its such a challenge but it will be worth it in the end i suppose. Im pretty excited! I'll be posting a build thread in about a month or 2.
  • Like 1
After owning my modified BMW 335i for over 3 years, the Skyline is a phenomenal daily when it comes to servicing costs and repairs (anything 1/2 major breaks on the BMW is like over $1k for the parts and multiply this by 3-4 times if buying locally)...
So much so I parked the BMW for now (currently suffering from ABS failure, leaky turbo seals, adpative head light failure and some other random ECU error codes) and went back to driving the beater Skyline as a daily work horse =D
  • Like 1
The list of errors/faults on my BMW right now... :down:
14051626_10154322699882040_1727254749144294652_n.jpg.1f0dc7fa34d490329f5b4147b86c20d8.jpg
Basically a dead ABS control module causing all sorts of shenanigans, and water getting into one headlight (failed internal seal due to age) frying a control module that controls the fancy 'cornering' lights and a brand new ABS module is over $2k USD from US or about $4k locally from a indy shop for the part alone (and you still need to get it 'coded' with a proper BMW coding tool from dealership or indy shop even if you DIY the install)... :dry:
I must add that my Skyline also suffers from the same 'water getting into head light issue' but because there's no fancy electronic control modules to break there all I did to 'fix' was drill some 'drainage' holes on the bottom of the light assembly to let the water drain out... :cool:
Edited by Mayuri Krab
On 31 August 2016 at 10:58 AM, niZmO_Man said:
^ and that's why I don't understand why people say Skylines are "expensive" and "stuff breaks" all the time. :P
Bmws have always been known to be unreliable shit boxes though, in Germany they buy them cheap and run them into the ground but for some reason they have a prestige status over here
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
