hi guys, planning on jumping on the efr 8374 T4 1.05 bandwagon shortly, just wanted to clarify few things:
going for EWG, any benefits to choosing IWG?
looking at 6boost manifold, should i be going 1 or 2 gate option?
TIA
TIA
EWG is much better than IWG (and only available in .92 I think)
You will need twin gate if it's a twin scroll manifold or they might do a split single pipe.
external gate it is
whats the recommended wastegate port size for both single and twin gate options?
On 4/12/2018 at 9:17 AM, HarrisRacing said:
These are my old pumpgas results on 8374 IWG with nothing more than changing cam settings (increased overlap).
Sorry guys here are the results. Tapatalk didn't let me upload.
Oh and I want to qualify something in case someone dug any of this up from the past in this thread.
 GTR's are pretty hard to come by in the states and I went off the deep end with my build. My car showed up with a rod knock and I didn't really get to experience the factory twins in their stock form. I went straight to 2.75L stroker and BW 8374 EFR IWG .92 turbo on a 6 boost manifold. Well during my build I had the typical accusations of "American Horsepower" which bothered me and my car ended up running about 128 mph in the 1/4 on pumpgas and 93 octane. On our dyno the car would typically put around 575 whp down at around 19-20 psig boost. Then I tuned it on E85 with the new ECUmasters EMUBLACK and the car made 740 whp and 615 wtq at 30 psi tapering to 25 or so on topend...again I think there were neigh sayers about it. I shortly thereafter crashed the car before I could get to the track and prove the new MPH (and run my 9 second pass). Rest assured, I still have the car and the drivetrain is still good (foreshadowing here).
Anyway, fast forward I just picked up another R32 GTR. I spent the day checking it out and going through it. It has an exedy hyper single clutch, stock RB26 with N1 oil and water pumps (don't worry, I know), some filter pods, brand new Garrett -7 turbos, R34 intercooler, Greddy downpipe, HKS super Dragger exhaust. It was running STOCK boost at 10 psi and I'll be honest felt pretty dang laggy to me coming from my other car. Well I put the car on the SAME DYNO here (mine) and started turning up the boost and checking AFR's today. Here are the results and the car got MUCH more fun to drive with the increased boost from 10 psi up to ~17 or so today. Looks like I need to pull the plugs and gap them because it broke up right at the top on the higher boost runs (or there is an AFM limit on this ecu?). I don't have much experience with stock RB26 or stock format twins, but the car pulled very nicely on the street (once it get spooled up). It goes to show that a stroker and 8374 EFR completely crush the pumpgas results from my other car.
  • Like 2
9 hours ago, acsplit said:
Here is a dyno sheet of Jake Jones RB28 now with 9174.  The precision was junk for drifting too laggy. Most overseas drifters run an EFR so will be interesting to see what he thinks. Screenshot_20180423-232603.thumb.png.8a20d6960cdb71a9c3df7e4da5f32e43.pnga
Nice- fair to assume the blue line is the EFR9174?  Any idea of which housing on the EFR?
Interesting seeing the progression - Garrett > Precision > Borg Warner EFR.  Be interesting to see if he stays with this now.
Edited by Lithium
10 minutes ago, acsplit said:
9174 iron supercore 1.05 ewg.
https://youtu.be/GE_X_OJays8
Awesome, I'd have thought the 1.45 would be more appropriate but that still seems to be pumping out quite a bit of power even with the "smaller" housing.
  • Like 1
That's a huge hole that's been filled! Mind you, that 6870 probably has 200-300hp left in it
Yeah it's a bit tricky when two turbos being compared have fairly different flow potentials, it's pretty misleading if it's not made really clear that the "laggier" turbo actually is operating below it's potential to make that power while the "awesome powerband" turbo is probably sitting near it's limit to achieve the same thing.
On the flipside, 200-300 sounds pretty generous - >840 @ hubs is not messing about, the Mainline hub dynos don't seem as "happy" as the Dynapacks.
  • Like 1
Mine went 770 on dynapack and 780 on mainline with less boost and richer so go figure haha. Mind you it did have some very nice R35 coils throwing spark on mainline
Oh interesting - I guess I shouldn't be surprised, but a few Mainline lads have implied that the Dynapacks read a lot higher and I just went with that.  I wouldn't have expected the R35 coils to make much difference unless your spark was only just (or not) holding up before.
Edited by Lithium
  • Like 1
Was borderline previous, think gaps were just under 0.5 while easily threw spark at 0.8 with R35 coils
Ahh ok, yeah could have been a thing to muddy things a bit.  Still, it's a lot of power in any money - and I'm not sure a 6870 would make 1100hp @ hubs haha
No but I don't think 1000hp is out of the question with the right gear and tune
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • To what gain?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
