3 hours ago, Full-Race Geoff said:
The 9180 1.05 can easily supply 500rwkw worth of airflow.  the rest of the setup will need to support this, fuel is the biggest factor (knock)
Full-Race has a few in stock, there will be a sale for the big holiday in the states this weekend
BTW, I meant awkw, not rwkw.
21 minutes ago, Piggaz said:
Piss it in. 8374/1.45 on my setup went 517 AWKW at 122,000 turbine RPM. 490 AWKW with the 1.05 bum.
Thanks mate. Is that on a 2.8 and on 98 or flex? Looks like you were just under the line there - for the 8374, is it 125k max shaft. speed?
Paul , you have had the 1.45 on for a while now and at first you were sort of thinking about switching back to the 1.05.
You have had a few runs now and one today with Dan , have you made your mind up yet ?
2 hours ago, Nismo 3.2ish said:
you have had a few runs now and one today with Dan , have you made your mind up yet ?
Nugget. Spending money on the wrong things, needs a shift boot and a front lip ffs.
I am too upset to talk about it in depth right now but will update with more when I am back in NZ ?;)
Edited by Lithium
56 minutes ago, fatz said:
1.45 no good?
Dont they make like 4 million kw in seppo land?
1.45 has its place. Did the Huntley hill climb today and just doodling through it at a corner that I had huge issues with the twins, it was ready to turn tyres.
I won’t be going back to the 1.05. Sub 3000 RPM there is Definately a penalty to pay, it feels a bit “soft”, from 4000 RPM it’s fine. If you’re “driving it” it’s all there. The 0.92 IMO should be made redundant IMO. No need for it.
Still well infront is the -5’s that we’re on it either way.
Without the head work you have done and slightly higher CR 9.1 ish , would the 1.45 still give you what you want or just lag it to much for what you like in a Street car
Guess without some sort of comparison it would be hard to know how much difference it would make .
Stock head no.
Depends on what you want, what you’re happy with. Having driven both, I would want my cake and eat it too. If the engine ever comes out I’ll throw a V cam at it and possibly bump the compression up a tad higher. Cake and eat it too?
As you know I am thinking of doing some headwork ( never ends lol) wondering if anyone has a 3.0 or 3.2 Lt that has has the compression increased  up to 10.5 ish   , mine is down to 8.1 for whatever reason during work on the stroker build ?
Maybe also done  some port & polish work?
Back to back Dyno runs would be great
I will stick with the 8374/1.05
Of course you should do that.  8:1 is 1980s CR for boost.  But you won't get that increase by changing the head. You'll need pistons.
20% increase in capacity means a 20% increase in head flow wouldn't be a bad idea.  Easily achieved with sensible porting.  1mm bigger valves gives the perfect opportunity to properly do the seat angles and shape the bowl into the back of the seats.  And there goes 5 grand.
A decent full effort head costs as much as the bottom end. That’s where the last 15% of performance is found. Depends on how much that last bit is worth to you.
Sort it out Pete!
There will have to be new pistons to go with the new work, it will have to be done properly especially with the Vcam in the car, I already have 1mm OS valves
i decided that if I am going to pull the donk down, get it all done at the same time
Wouldn’t do it if I did not have E85 close by now ?
Sort it out Pete!
Yeah mate , as you know I have been tossing it around for a long time and can’t help myself, must do it , have to feel the difference when I press the peddle, like an Fn drug ?
Just now, fatz said:
Pulling down a running motor is just dumb
just saying
break then fix
Know what you mean but I am not going to break it anytime soon and at 76 , F it I want to finish It , just wish I knew what I wanted at the getgo, but I think there are many blokes doing work on their cars and the goal posts just seem to keep moving
But I had no idea I would go this far , it just gets in your blood like herpies and just keeps coming back when you think it over ?
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
