They are available lith. Not for black series yet but definitely available for all other efrs. Good for people that have cut up their efrs to fit elbows or don't need bov.
https://www.full-race.com/store/borg-warner-efr/efr-components/borgwarner-efr-compressor-cover-sx-e-style/
Well there we go, that's cool - thanks!!
6 minutes ago, burn4005 said:
I check this thread daily for the same reason. Can't find any results anywhere on the net for any engine at all running a 8474 other than rt Ernie on the evo years ago.
Ditto. Been keeping an eye out for results for any of the black series and found bugger all.
This wee clip of a 9274 on a 2.2 stroker Evo X suggests they spool well for the size:
On 6/1/2019 at 10:36 AM, gixer said:
On bottom mount T4 twin scroll manifold, will an EFR 7163 CHRA be sitting  higher then 7670 one? Thanks
It depends on where you are measuring exactly -  The manifold side Turbine Inlet and downpipe side Turbine outlet are identically positioned between 0.80 and 0.92 a/r.. there is no difference in axial position.  However the 7670 has a longer CHRA (axial length) and moves the comp housing out further forward.  additionally the B2 frame is a larger bearing housing with fittings that stick out farther from the center.
I dont know what engine or manifold youre looking at or what point you intend to measure - they are similar. although slightly different
ill find some time and dig some up, we just had an evoX with good results and this week at pike's peak a friend of mine will be giving his k20 / 8474 0.92 the stick with an unlimited class Pikes Peak entry this year.
thanks for the plug, SXE style comp covers are available for the legacy EFR turbos.  Waiting on this for the newer 84 and 92 turbos
Edited by Full-Race Geoff
small correction for your website Geoff, the selection currently is shown as "8374 or 9174 compressor cover"
the 9174 option should be with the 9180 as its the compressor size you're interested in, not the turbine.
  • Like 1
9 minutes ago, welshy_32ZILA said:
Lith have you seen that Garrett have released their new g turbos in mid frame. G30/35. Be interesting to see where they sit on your table of flow.
Yep, I posted in the thread which is about Gseries - will update the table when exact dates is available. Some extremely promising looking options there
  • Like 1
10 hours ago, Nosure said:
8474 1.45 a/r on the way.  Should finish it next month sometime.
Very nice!  What kind of setup is it going to be working with?
This is definitely the combination of the range which I suspect has the potential likely shine on an RB
Edited by Lithium
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
