my BOVs were leaking and the turbo was doing about 8000rpm more than it should have been based on the compressor map / VE mass flow calc and Pressure ratio from the ECU.
put in new BOVs and it was back down where it should have been.
1 hour ago, Nosure said:
I checked. It’s 14 blades. And we did some cams adjustment first. Did not help much. But still make 430awhp on 14psi.  So this 8474 still make more hp/psi even on very low boost.  I just need turn boost up until reach 125k rpm.  If it’s accurate wheel speed reading i think It will hit speed limit by under 25psi.
What capacity engine is it mate?   2.6/2.8/3.0?
I have 2 bov. 1 on turbo (plumb back) 1 on intercooler pipe.  The one on intercooler pipe is 100% work fine.( we already done pressure test) But I’m  not sure about the plumb back bov. If that one leak I might have high wheel speed low psi problem.   But if everything work fine i will just max the turbo and see what it can do.
6 hours ago, Nosure said:
e85.  But if only 20psi. I think I can run 98:).
Its 2.8.
I’m going to change stock efr bov back. Now I have turbosmart plumb back bov on turbo. That make sense if bov leaking.
Turn the one on the comp cover up as high as you can. That should do the trick. ?
Ahh.  I would probably sooner run a blank on the EFR compressor housing than go back to the stock one if you have another BOV, I get the impression the stock ones are not great.
Or this, if it's an option
for reference, I was talking about the stock twin BOVs on my setup leaking, I have a blanking plate on the turbo housing bov, I swapped out the stock ones for 2x GFB mach 2 plumb backs which bolted onto the stock bov pipe and wound them up pretty tight.
I wasn't happy with the oriface size on the comp cover bov for the high flowing turbos (83 and 91mm versions). was still getting loud choof (comp surge) with it. no such issue with the mach 2s.
  • Like 1
33 minutes ago, Nosure said:
Stock efr bov does the same.
As comments above warned, it's not unusual for the stock BOV to leak.... trying the stock BOV wasn't necessarily going to rule it out.  If anything, it could be argued that it proves that the other BOV may have been leaking as well if you didn't end up with worse turbine speed - as this is the reason people often blank off/replace the stock one.
Fingers crossed it's either not an issue, or something else.   Good luck with the rest of the tune!
Edited by Lithium
Yeah I’m getting blank plate tomorrow. And test it again. At moment 25psi drop to 22psi on high rpm already on limit of 3 ports solenoid, turbo speed is 114k. Now we need change to 4 ports boost solenoid to increase boost and get bov blank plate to test if it’s leak.
timely post, im weighing up replacing the stock efr bov with a turbosmart one, recall Geoff posting at higher boost (25-28+) stock needs a stiffer spring, hadnt heard much re: comp surge on these (i have 8374 1.05), but im now leaning towarding biting the bullet and replacing twin factory bovs with turbosmart items
On ‎11‎/‎08‎/‎2019 at 10:20 AM, Nosure said:
So far I got 610hp on 20psi with 8474 1.45a/r. And 280 272 cams.
My 3582 gen2 0.82a/r with type b cams Made around 500hp on 20psi.  But 500 rpm sooner.
the 8474 already over 100k rpm. I’m not sure it was read wrong or something else. Will do some cam adjustment and boost up early next week.
ill be running 8374 1.05 on 2.8 vcam shortly on e85, starting to think i should have upsized and/or gone black series
On 8/6/2019 at 4:37 AM, R.3.2.G.T.R said:
I assume you opted for 3 port Mac valve instead of std offering
the OEM borgwarner EFR / pierburg solenoid is more desirable than 3 port mac.  some tuners prefer twin pierburgs to a 4 port mac. Certain other turbo manufacturers even purchase these solenoids from Full Race, it definitely is a quality piece to come standard
On 8/10/2019 at 8:20 PM, Nosure said:
So far I got 610hp on 20psi .. the 8474 already over 100k rpm.
On 8/11/2019 at 9:33 PM, Nosure said:
Yeah. There is no leak or any mechanical problem.
EFR 8474 on RB 2.8L revving to 8000rpm @20psi at sea level is likely in the 420-440m/s tip speed range depending on VE and other factors.  You said you are seeing over 100krpm shaft speed...
450m/s tip speed on an 84mm compressor = 102k rpm.
450m/s at 20psi sounds like a leak, but im thousands of miles away and purely guessing here.  What pressure are you boost leak testing to?  Are you at altitude?  Many variables at play, so I suggest to further inspect the TB shaft seals as well as the intake manifold sealing surface.  good possibility there is a small leak in your system
Edited by Full-Race Geoff
fyi - all EFR turbos include the stiff BOV spring since mid-2018.  this was a change i rallied for, you guys should not need to change it.
the oem configuration vents from 360 degrees, so i prefer this design to the turbosmart which only vents through a slot.  if youre going to change the EFR bov, i suggest to go to a traditional external rather than a plug and play
  • Like 1
We did a test with a standard EFR BOV with a low power setup and we were seeing slight leaks even at 25 PSi region, where we got a little increase in power by blanking it.  So it's definitely something to address.  This would have been the pre mid 2018 one.
My Nitto 2.8 Vcam 264 / ex 260 setup with EFR9180 will be on the Dyno in coming weeks.
I'm looking at then using this same setup to test a 8474 to see if the front end can produce 9180 like flow.
Then also looking at testing a 9280, to see how it compares against a 9180.
  • Like 1
That's good to know!
That will be some very interesting testing!  Particularly the 8474 versus 9180 stuff, as the 8474 actually appears to have the edge on flow - it'll really clear up how much of a choke point the 74mm and 80mm turbines may or may not be.
Hope the setup has lots of data and all the supporting systems, needed... you could end up with a pretty serious performer from this, not to mention have the kind a data a LOT of people would love to know about :)
Hi we did replace 3ports to 4ports.  We tested both oem and turbosmart bov. They both does the same job. Now I’m going to use a blank plate.
So far there are no leak we can find. And shaft speed 23psi on 8000 rpm is 114krpm made 630-640awhp.  After we change to 4 ports we will increase boost see what it can do.   Same dyno we got 660hp at 28psi with 3582gen2.
Something really doesn't sound right, are you going to the 4port due to having issues holding boost?
If you are maintaining 23psi through the run and your wheel speed is 114,000rpm then the turbo is moving a LOT of air, like over 90lb/min.... but you are only making 70-75lb/min power levels:
What kind of ECU are you using?
And if you are operating at that point on the MAP that Lith shows - its not very efficient at that point of the map - so are your intake temps getting very hot?
If they aren't this might indicate you're not actually at that turbo speed and perhaps you are reading it wrong.
If they are, then I guess that backs up that you are working the turbo hard and there is likely a leak.
The tricky thing with hot intake temps is with some of the really good intercoolers these days I've actually seen people "off the map" and still have reasonable intake temperatures, so you can't actually be sure that is the issue.... pre-intercooler temps will tell a clearer story there.   I'm betting that exhaust manifold pressure is going up big-time, and it's part of why I asked about the boost control.
At the moment it seems a lot like either the engine isn't converting the airflow into power well, or the airflow is being lost somewhere - like a boost leak or something (as is a recurring theme in the line of questions).     This is one of those cases when an airflow meter is handy haha, but with the wheel speeds being mentioned it seems a lot like the turbo is working hard.
I suppose there are two other options which could cause this kind of thing, if there is an intake restriction pre- or post- turbo - like if someone left a rag in the intercooler or something when things were being changed over.... that would mean you wouldn't see a leak, but it would boost the pressure ratio across the turbo HEAPS but you wouldn't see that pressure at the intake manifold.
Temperature and/or pressure at the compressor outlet may help build a better picture.  I'd be wary of pushing it much harder without getting to the bottom of what is going on, as it seems like the turbo speed is probably configured right it means a lot like something isn't performing correctly and it's costing power, probably spool, and could compromise reliability too.
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
