12 minutes ago, iruvyouskyrine said:
You would think that but it's not. It's a parallel thread, and it's not M10x1 because that's what I took a punt on and the thread is about half that size ?
Um.....female pipe threads (BSP, NPT) are always parallel. The taper goes on the male.
Pretty sure its metric, did it over Christmas. Maybe M8? Don't have the reference catalog here but it was pretty much the only option in metric for a -3 male fitting for that thread size.
Edit: well, for an 8374, maybe its different on the smaller ones?
I distinctly remember how odd it was that my USA designed turbo had metric threads and the Australian Designed Turbostmart wastegate had imperial threads.
There's not really any such thing as "metric pipe threads". When we're talking about screw in fittings, and elbows and Tees that go onto pipe, etc etc, there is really only 2 dominant threads. BSP and NPT. The Yanks, the oil & gas industry and a few others are stuck on NPT. The rest of the world pretty much uses BSP. The Europeans call BSP threads by other names though. If you see a German company describing a threaded port or stub on their equipment, they will call it G1/2" or G15 (same thing). And there are other variations on the theme.
M8 is a bolt thread specification. It is really not relevant to "plumbing" fittings. People don't use metric bolt thread forms for tapered male into female sealing threads. They may well use metric bolt thread forms on collars of fittings that use seats to seal (like Swagelok or other similar pneumatic or hydraulic fittings) but they are just as likely to be imperial/American or totally custom in those systems, seeing as they are usually proprietary anyway.
  • Like 1
Yes, and look at the conical seat on that port. It is clearly meant to work with a bespoke fitting that has that cone on it. Seems silly, when everybody else would just use a 1/8" NPT or BSP parallel in there, with a tapered fitting.
I mean, good on the yanks for doing something, anything, in metric. But dumbo points for using a metric bolt thread for a f**king plumbing fitting.
48 minutes ago, taijohnsen said:
It's not that big of a deal really...
Well, it kinda is. They've used a thread that looks about the same as a 1/8" pipe thread, but isn't. Then you either have to use their fitting or go out of your way to get a fitting that has that thread on it, which has got to be about 100x more difficult than just getting something with a 1/8".
50 minutes ago, taijohnsen said:
Conical seat would be for an o-ring I would have thought.
But then it wouldn't tighten up. You'd be relying on a threadlocking compound to stop the fitting backing out.
3 minutes ago, burn4005 said:
Why not? AN fitting ORB threads are parallel and they seem to be fine.
Because an o-ring is a cushion that prevents the male fitting from pulling up hard on the external seat of the connection, unless the o-ring is deformed beyond intended design in that conical seat.
That seat is not designed for an o-ring.
AN fittings do not look like that. Parallel threads are of course completely normal on collar type fluid couplings that have conical metal on metal seats. This is not the same situation.
Agree with what you're saying re the fact that metric pipe threads are not a thing, but in the end, it is a M8x1.0 thread. And Speedflow makes a fitting for it so it can't be that rare of a thing: https://www.redlineauto.com.au/p-2547-speedflow-349-04-m8-x-10-to-4-male.aspx
For what its worth Iv'e had one in there for a while now, leak tested to 30PSI no issues, doesn't seem to back out at all (steel fitting in aluminium probably helps there). If you're that worried put some sealant on there.
How the actual f**k do brake fittings work!
Here is the short version. True pipe threads seal on the threads. Other applications use a standard thread then use a gasket/copper washer ect.
And then you can also seal on a tapered bit but thats another story.
The end of the brake pipe is flared. That forms the female part of the cone seat. The male part of that is either buried in the bottom of the threaded hole (say on a caliper, MC, prop valve) or in the other fitting, if is just some coupling fitting somewhere partway along a line.
The "nut" that is on the brake line has a male thread that screws into the female thread (on the caliper, etc) and pushes on the back side of the flared end of the pipe, pushing it against the male flare.
So, it is a tapered seal, as per your discarded throwaway line at the end of your post.
Simples, squeak.
Or were you being ironic?
Not unless it's bleeding boost or compressor stalls on throttle lift off...
My 7136 used to comp stall a lot, and I  don't have a VL commo, so I put the 50/50 kompact shorty on it with a lighter spring.
I'm not using it any more if anyone would like it. It's bronze now, not black tho...
15 hours ago, Timmaz300 said:
Is there any reason to upgrade the factory recirculation valve for a Turbosmart recirculated or 50/50 valve on my 9274?
What are the temperature ratings on the Festo pneumatic hose and fittings?  It looks nice and neat and definitely easy to install. But I'm a bit sceptical it would live long on the hotside there? ?
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
