Thanks mate!
any progress is good progress right?
cars back- still waiting on the doors and other panels
rear belts, seats, tail lights and dash are back in for good.
tried to repair the felt inserts on the rear trim. Looked good at first but began to unravel again- ordering new ones.
ABS Is sitting in place, next up is tidy up the engine loom and get that back into its home and adjust the cooler etc so it’s all sitting nice and level
plenty of work to do
  • Like 1
  • 2 months later...
Got a little more done over the past month or so
panels hanging on
clutch hydraulics run and fit up.
copped a bit of a slap with work and have had to settle for a pfc for now
halaltech, maffless and leather retrim to come.
is it going to be lebo diamond stitch spec? You bet your sweet vanilla ass it’s going to be!
getting very close, the list is small now!
  • Like 4
  • 5 months later...
Back again.
slow progress as usual
got the car idling on e85 and it’s very much drivable.
ended up cracking the shits and deleting abs
went with a raceworks twin entry rail, push lock fittings and a direct wired pump feeding some 2200cc injectors
glass in
car detailed.
Wheel alignments done
Some tiny little hiccups here and there that I’ll get around to eventually
But all that’s really left is a tune and rego
  • Like 3
  • 3 years later...
On 08/08/2019 at 5:09 PM, Dose Pipe Sutututu said:
Inshallah!
haha! well im not dead, still have the car, never built the house due to covid.
never got to do that skid; did eventually get it on the road and have driven it maybe 12 times over the year lol
just ordered a pulsar g35-900, going to send it and see what happens
  • Like 1
You're alive!
And congrats on your first skid lol.
Umm... if you're bored have a look at my build thread OR IG https://www.instagram.com/nhbautomotive/ ... a lot has happened in 3 years
1 hour ago, Dose Pipe Sutututu said:
You're alive!
God damn, looking good man!
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
