5 hours ago, ActionDan said:
Sorry I don't follow? I thought we'd all agreed that -9s were relatively responsive? Or is this a lead in to telling me to go single :D I'm in Vic, not happening.
I'll try Simon, cheers.
I have HKS GTSS (-9). Bloody responsive as hell. I.E I have 20psi by 3900rpm and 23psi (i have head studs) by about 4300rpm. Gained roughly 60 to 70KW in the low- mid range compared to my old -7 setup.....
My exhaust is restricting me up top now :-(
I plan on getting Type R cams sometime next year too...
2 minutes ago, Dose Pipe Sutututu said:
Yep, seen it. Noted the feedback on here that the real world dyno testing wasn't as generous.
I'm on 25psi by similar rpm, also headstuds.
What are you basing that buying decision on?
I want a mild cam, but not lose 25+ KW between the 75km-110km (3-4 ishkrpm zone) I guess my buying decision is based off the dyno results I've seen with those that run Type B, and figuring the Type R has the same lift, with almost stock duration. I can live with a few KW loss in the lower end as the -9 is really responsive anyway.
Fair enough, what gain are you expecting from mid to top end?
1 minute ago, Piggaz said:
Another option is the Mines Shore pro 2 shafts which are 252 @ 10.05. A little more expensive though. Almost another 1 mm of lift though.
I've heard about these before, fit a standard head? No risk of smash smash with that lift?
1 minute ago, Dose Pipe Sutututu said:
I wouldn't say a dash -9 setup is responsive at all... that's just me.
Agreed, not in the way that stockers are. My 33 with standard R34 BB's on it and 18psi was a beast for traffic light grand prix.
My 34 would reel it in and blast past one the speeds climbed though.
They come with new buckets. I *believe* they drop into a factory head but can't confirm.
and even though the -9s hit 23psi or so by 4300rpm.. before that magical RPM.. it makes less torque and less power than a diesel Golf.
I'm making 180 RWKW at 100km/h. I'd say that's about on par with a 4ltr Barra motor :-)
not exactly the same setup as yourself but for reference...I managed to shift full boost (18-20psi) by 400RPM just by playing with cam gears without losing any top end.
I have RB26, -7's, 98RON
I went from 2 degrees advanced on inlet, 4 degrees retard on exhaust......to 6 degrees advanced on inlet, keeping it at 4 degrees retard on exhaust.
  • Like 1
smart move...
Cams will NOT give you response
  • Like 1
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
    • That could easily make a horrible noise. +1 to the benefits of: a) Disclosing all relevant information when asking questions such as these, b) Actually going out and having a look at your own car, seeing as you're the one there, and we're not!
