21 hours ago, Hadouken said:
Wow. You're in your 30's and complaining about the gtr being uncomfortable?
Soft man, soft.
*Looks at the suspension in the car...*
I see the issue here. :D
  • Like 1
Josh said:
With a lovely chassis like the 34 with some decent rubber and power, the valving performance offered with the X-R series I feel would be ideal.
The Blue series are an excellent package for the price point but are a street/comfort orientated style setup that when using your car for even spirited street driving may not offer the support needed with your level of rubber and the AWD. Blue series are $1590 inc GST and come with default spring rates of 9kg front and 3.5kg rear.
The difference between the X-R and X-C is all in the valving, this determines how a shock works and gives it its characteristics. The X-C series are developed for comfort and ride quality only, so again I feel if wanting to exploit your chassis and power this would be a little lacking compared to the X-R series.
The X-R series paired with the spring rates recommended are aimed at being the best blend between performance and ride quality with only our custom valved Red series offering a better blend.
Nah, get the Blue and tell them street use ;).
Massive difference between my TEIN and Ohlins (all second hand), Ohlins are "street" setup and valved/sprung softer, so driving around is much nicer.
TEIN and current HKS suspension can get airborn, Ohlins rode over them quite nicely (for a short stroke damper).
Would be even better with the "better" R34 chassis. But then I don't know how smooth your roads are compared to Sydney.
A mate bought some Blue for his Evo8, probably more comfortable than the stockers.
On 10/29/2016 at 11:15 PM, Terry_GT-R34 said:
Post-2011 ISF
Magnificent low Km "IS-F" at Earlwood/Sydney. Silver.
I've driven this one, and it's nowhere in the 90s..., or 80s..., or 70s...
You can contact God_speed here on SAU
1 hour ago, ActionDan said:
What was your take on it Terry?
* Response is immediate without hesitation
* I never used the brakes in quick succession to detect any fade
* Cornering is really good whilst having driven M3s before. Good tyres on the car help of course.
* Power curve through the gears is strong and seamless
* Steering has good feel but it's not as connected compared to a GTR of course.
* Comparable certainly with any  M3 I've driven. So whilst it's a buyers market especially for the next 10 weeks, try it out. when you plant your foot down, the V8 sound is sublime .
  • Like 1
  • 3 weeks later...
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
