Injector loom modified, injectors fitted, splitfire coilpacks fitted & engine loom wiring in progress...5947b1ec03160_enginewiring.thumb.jpg.f8cefb44982d82e0f6b0358dd8aa012e.jpg
Ditched the thermofans as they weren't really keeping temperatures under control, back to engine fan but a bit too close for my liking...
Have purchased GKTech engine fan which supposedly is thinner & more efficient (win-win) - on its way....
Dummy-fit the top intake manifold & Neo engine cover to see how it will all look. So far so good! Couple of hoses on their way from Japan to finish the intake plumbing...
Hopefully finish-off the wiring by next weekend & get the car ready for some intercooler, intake pipe & dump/front exhaust fabrication!
  • Like 1
Loving the progress, making me lean more and more to doing a neo rather than a standard RB25! you had any real difficulties with the wiring so far? or has it all been pretty straight forward?
  • Like 1
Wiring still in progress but a lot trickier than a s1 rb25 motor.
The neo loom has so many plugs for TCS, ABS, Sensors, Headlights, etc so its been slow progress to work out which to keep & which to cut.
So far, Ive worked out that the rb20 ecu grabs ignition voltage near the plug at the airbox and its a matter of wiring this to the brown eccs/ign relay & another pin on the ECU.
Im trying to make sure aircon, power steering, hicas, wipers & all dash switches/sensors work with the Neo so am tracing each wire to each plug and working through it slowly.
The Knock subloom on the r32 is separate and connects into the rb20 engine loom; whereas the Neo knock loom is integrated into the Alternator subloom; still working out best way to connect into the Neo loom.
  • Like 1
Working on all the little-bits to make the car go...
Time to flex!
Nothing beats new parts...replacing the coolant lines.
New clutch slave cylinder with custom hose
Tailshaft shortened, balanced & fitted.
Replaced the 30mm Turbo spacer with a 20mm spacer, much  better fitment now, hopefully the dump/front clear the aircon lines now...
With a 7ltr ASR extended sump, means more oil - bought enough for two changes & gearbox oil to suitoils.thumb.jpg.6e066d3e750d15669343cb30b8c2ae10.jpg
Hopefully next week we will be in a stage to fire-up and see if my wiring has been done right!
  • Like 5
On 7/14/2017 at 5:34 AM, rx-line said:
What compression pistons?
Specifications
Part Number: SC7297, 14028-6
Make: Nissan
Engine(s): RB25DET NEO
Year(s): 1998-2002
Piston Material: 2618 Aluminum
Bore Size: 86.50mm
Compression Ratio: 9.0:1 CR
Connecting Rod Material: 4340 Forged Steel
Connecting Rod Length: 121.50mm
Compression Height: 1.220"
Wiring loom finally sorted and Nistune + flex board soldered in.
Despite AFM plugged in, larger injectors on a stock map and no intake pipe connected, the engine cranked & started!
Car will be towed to fabricator and tuner on Monday, hopefully have a running car this Friday if all goes to plan :)
  • Like 4
Some fantastic work done by Havoc Fabrication, their attention to detail, care and professionalism is above all else. Thanks to their workshop for tackling this mammoth of a job.
  • Custom stainless steel intercooler piping with zero holes cut
  • Custom stainless steel intake pipe from z32 airbox
  • Custom stainless steel dump & front pipe with another cheeky o2 bung for wideband sensor/tuning
A couple of wiring gremlins to sort out last minute but the car is ready for run-in tuning this Monday :D
  • Like 6
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
