I did some more work, I removed most of the remaining interior including the roof lining, dash and heater parts. I starting labelling the wiring loom and connectors to make the job much easier when it comes time to reassemble.
I also had some new seals for the doors arrive
and a blanking button for the cigarette lighter
Had some parts come back from powder coating also, the bumper supports and the bonnet latch support
  • Like 1
So to recap I bought the grill on Yahoo Japan, from the pictures I could tell it was rusty but thought I could simply dip it, repair and then refinish it. When it arrived it had a lot more rust than I'd bargained for!
As you can see the base and supporting brackets are pretty much dust.
I drilled out the old alloy rivets and disassembled the grill. The mesh and surround are actually stainless so I had this dipped and linished ready for paint.
So quite a few parts were well beyond saving. I send the top section away to be dipped and zinc plated with some other stuff. It came back with quite a few small holes where the rust had taken it's toll. I filled these with lead and then rubbed the surface back flush ready for filling.
I had the lower section and brackets remade by a local custom body shop. He did a great job!
I'll rubb back parts including the plastic ends and prep them ready for priming then reassemble ready for paint. Some people are probably wondering why I bothered with this grill instead of buying a fibreglass replica, I just prefer to use as many original parts as possible and enjoy resting these old and broken parts.
  • Like 1
I dig that. As OEM parts become harder to find, repairing over replacing is such a good alternative. Well done, you're saving parts from the scrap heap. :thumbsup:
I'm trying to track down photos over 3 laptops, 4 phones and 8 years, it takes time, hahahaha. Amazing how one or two photos go missing.:)
Ok, I'll let you off. I'll watch the cricket instead.
BTW - I'm happy you're using the SAU image hosting. It ensures that the images will be around as long as the site is (At least another 30 years).
  • Like 1
This time I'm ONLY using SAU hosting. I don't want to have to do this again. ;)
I pulled the old wiper motor off my car to clean up. Seems someone decided that spraying it black with a spray pack was a good idea...
One thing I do like about the old 70's stuff is it's serviceable meaning it can be pulled apart and put back together. I sent the alloy body away to be hydroblasted, the metal away for zinc plating and I cleaned up some of the screws.
A word of advice if you're looking to do the same, the rivets used to hold the bearing in the end of the rotor housing are alloy. When the housing was pickled before plating they dissolved and the bearing assembly fell out. Luckily the strong magnet it the housing held the parts in so they were not lost. If I did this again, I'd drill them out prior to plating. The bearing was slightly melted and had to be ground out so the rotor would run smooth then I pop riveted the internals back in.
I had to drill out the alloy rivets used to hold the plug in place too, I replaced them with some M3x15 screws with nylon nuts and a pop rivet which worked well and the finished product came up really well.
I also picked up a tool kit from which I cleaned up
Got the boot and bonnet latches back from plating too.
  • Like 1
The original Nissan/Datsun steering wheels have a nasty habit of rusting, much like the rest of the cars.
Rather than having to deal with this again I decided to rub the wheel back and spray it silver.
I then sent the wheel off to be trimmed like the GTR and fitted the refurbished GTR horn pad. It looks amazing!
OMG that steering wheel might be my fave part so far.
BTW, this is because of you;
"You are only allowed to give 20 likes per day. You cannot give any more likes today."
  • Like 1
Rather than buying new horns I thought I'd strip down and clean up the originals.
I had the cast rears water blasted and rust treated because it was going to be to tricky to remove the internals for dipping. The came up nice though, it was probably the best choice in the end. The gaskets were totally stuffed so I bought some gasket paper and remade them also.
I reassembled then tuned them, they are loud! My hearing was a bit NQR after that haha.
Also got the bonnet stand prop rod back.
I spotted some beautiful velocity stacks on Sudou-san’s Hakosuka from Garage Saurus Suro-R at the Nostalgic 2 Day event recently. As soon as I saw them I had to have a set :D
I these made in Japan by Technical Garage Sasaki to suit Solex/Mikuni 44's. They are 80mm flared velocity stacks in titanium with heat treated tips. I removed the old studs from the carbs and fixed them with matching titanium hex head bolts, not sure if I'll keep the titanium fittings yet. I also had the fuel feeds re-plated and the brass studs on the manifold hyroblasted as they were not looking the part. Now I'm only waiting on the linkages to come back and they are complete.
2013-04-21 13.50.10.jpg2013-04-21 13.49.55.jpg\\2013-04-21 14.22.42.jpg2013-04-21 14.23.33.jpg
  • Like 1
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
