I'm skipping that and going straight to motor/box out, then I'll look at the head and you can come over for some beers and laugh...
I must say, it has survived many many many many track days and numerous anti-lag 2-step launches too (on private property ahem..)
On ‎12‎/‎12‎/‎2016 at 5:35 PM, Dose Pipe Sutututu said:
fuuark that, big cams are gay on a stock motor.. I would go big cams if I had a built motor, solid lifters, cnc ported head, blah blah blah and rev it's mum to 10k rpm witha  sequential box.
But nah.. it's a stocker heap of shit.
Goal: 400kW stock bottom end.
It can still do it! lol
LOLOLOL.. yeah and watch a few rods go through the block when the rest of the Ringlands are smashed and snag on the cylinder walls lololol
See no worries, you'll still have a few rods in there, gotta keep it positive lol
le siet bok updates, pulled off cat (turbo shrapnel filter) tapped out bits of engine and turbo:
then went onto disconnect all the hoses, accessory loom, blah blah blah. Removed the AC compressor, powersteering pump and cabled tied them both out of the way (don't want to regas because tight arse asian). Removed nuts on engine mount. And yes, something had to go wrong.. ended up snapping the coolant hose connector that goes from motor to firewall. Lucky wasn't the heater core hose fittings.
And yeah, managed to take off the bonnet on my own, aesthetics - not really I've gone fat.
So now, as you may have seen in the WTB section, I'm searching for a motor being a neo or just a built rb25det. Let's see how that goes :)
Unfortunately with so much going on, I won't have much of a budget to fry. Just waiting on NST to go up in price and I'll sell my shares to build this turd into a glorified fast turd.
  • Like 3
so yeah, a bit pissed on straya day but the motor came out.. barely... I forgot to remove the shifter LOLOLOL...
We were like wtf.. the motor and box was jammed, looked underneath and "f&%k c&_t, piece of shit c¥×t"... so motor back in ish, then shifter out then round 2 and now we're here!
  • Like 5
Happy Lunar New Year, also treated myself to a new trolley jack because it's red and red is a good colour during the New Lunar Year lolol.. (I have 2x jacks now lol..)
Also took the box off, and yep that's it for now.
On 28/01/2017 at 2:04 PM, V28VX37 said:
Show us the block and pistons Johnny!
soon my friend, the gearbox bolts are too short to mount the engine onto the stand lol.. need to sort that out first!
20 hours ago, Manuel Kasko said:
Engine for sale in VIC
After a built motor in Sydney, but thanks anyway man!
  • Like 1
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
