Off with her head, as per the queen's orders.
Cylinders 1 and 6 looks like they've had a chance to chew up and spit out metal bits. Slight scoring of the bore in cylinder 1. Sump plug has grew a metal Christmas tree, no chunks of metal this time round.
Hectics..
  • Like 2
Theres a shortblock on gumtree
Get you out of trouble for $550
Just dont lean on this one as hard and should last
Also is your fuel rail dual entry ?
Please view this ad:
Nissan RB25DET Series 2 Engine,
http://www.gumtree.com.au/s-ad/pymble/engine-engine-parts-transmission/nissan-rb25det-series-2-engine/1137558607?utm_source=com.google.android.apps.docs&utm_medium=social&utm_campaign=socialbuttonsVIP&utm_content=app_android
Download the application from the Google Play Store.
http://goo.gl/7NzhP
http://goo.gl/7NzhP
Yeah saw that, but fuuark it I'm aiming for the stars now lolol..I'll end up blowing up that motor too.
Just waiting on share prices to climb a little more then I'll sell and buy all the guts.
Because it means I will need to cut my dump/external plumb back and extend it to suit.
Too much work needed, I rather a super reliable RB25 than a 300000km RB30.
Spent about 15 minutes taking off the ancillaries and engine mount brackets blah blah blah. They now sit on a shelf.
  • Like 1
    • So I put it to 3bar (43.5psi) while priming. It stays at 43.5~ as I crank shakes slightly. Ive also tried dropping pressure to see if that changes anything. I replaced the fuel dampener because I was troubleshooting the system along with the stock FPR (swapping them one by one to rule them out). But i only got up to changing the dampener and it started running again. Injectors are stock second hand. I did a bench test on both my original ones and the secondhand ones. The second hand injectors I have in the car now spray slightly stronger than my original injectors.
    • I knew Andy from about then, it did some cool stuff. By 2005/2006 era, he also implemented closed loop ignition timing tuning. In 2004 it was pretty cool, being with him when he was doing automated fast self learning tuning!
    • Im No tuner but…. im running a 25det with north of 600wkw at 9000rpm e85 and water meth. G40 1150 on 32psi. Having a real built head will flow a crap ton more power but you being stuck at 7600 won’t be helping at all, throw all the boost you can and nothing will happen. Solid lifter and 9000rpm is the only way,  I have built my motor 3 times, not from engine failure but more along the lines of my failures in not understanding engine parts better, basic phrase to help, “block hold power”  “head make power”
    • What's the fuel pressure while the car is cranking? Curious, why did you replace the fuel damper? What injectors are you using, are they brand new?
    • I think it's terrible value, it should be half that price IMO. And I'm known as someone who will unironically suggest the GTIII-SS on the RB26 if you have very specific requirements. The GCG RB25DET "hybrid turbo" is 1/3rd the cost of this GTIII-RS kit and sounds like it should fit with zero modifications. Talk to Hypergear as well, maybe they can do something that fits your requirements.
