Baffled Sump by the look of it? I always liked the prospect of the HOR extended sump but I read its a pain in the ass and can only be fitted with the engine out. Lucky you're already there ;)
Baffled but not gated, feeling a bit poor haha.. Yeah you "could" do it motor in but at that rate you might as well take the motor out.
Some progress tonight, I removed the crank. Some scoring on the bearings so might change all of them too :(
I was hoping on the conrod bearings needed changing but YOLO right? I still want to retain the standard NEO rods and NEO pistons because they said not to let the Nissan out *ahem* @GTSBoy, @Piggaz. Nissan hasn't been let out lol.
Oh hai! Looks the goods, sump was modified to suit the AWD motor going RED as the pick up sits more forward. Test fitting was spot on, I like very much - great success.
Off to the machinist it goes, the silly crank.
43 minutes ago, admS15 said:
Nissan is well and truly out now brah. You've contaminated it with Sydney air. Should be alright though. #RBLIFE4EVA
Still stock!!!
Crank at shop, but their machinist has buggered off overseas for 4x weeks!
Thinking if I should do connecting rod bolts too lol.
Still stock motor :)
  • Like 1
Are stock bolts capable of 400rwkw?
If no, then replace.
Given the driving style I'd worry more about balance/harmonics/oil pump strength etc.
Unless the rod bolts are a known weak point?
Got a good balancer for it?
1 hour ago, Dose Pipe Sutututu said:
derno, Matt Wooten & TIm Burt don't seem to have issues with stock oil pump, stock rod/bolts
Soooooo why did you pull it apart if these guys have been trucking along for years with the stock setup?
just to install the Spool oil pump gears and to install a new head gasket - that was it :)
May have gotten a tiny bit carried away with the headwork but that's just it.. everything else is just pretty stock
  • Like 1
Actually had free time for a change, which I rarely do.. so decided to do some work on the siet bok rust bucket.
I always has an issue where the camber kept changing every track day and I had a feeling the OEM camber bolts were moving so I decided to deleted the bastard with this GKtech camber lock out kit.
On removing the OEM camber bolts it was evident the machined groove and offset washer weren't working correctly, most likely slipping when I'm smashing into ripple strips.
Man 60% of yhe arms are Hardrace lol.. bastard should sponsor me!
  • Like 2
Yeah cnuts!
Removing those stupid machined screws are not fun, used those impact/hammer screw drivers and a bit of heat. I bashed the shit out of the pump like Pacquiao vs Horn and eventually all of them came out.
Yay, it's not broken but who cares we are going billet!
Result? Billet oil pump gears, hectics bro - can smash limiter all day like a JZ now!
  • Like 3
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
