More OEM goodness, special thanks to Andrew @ Kudos Motorsports for the parts. Cheaper, faster than Nissan themselves so winner in my books!
Ooo.. The dowels are in, more soon :)
Stock pistons look good after a clean ?
  • Like 3
Oh yeah, ARP 2000 studs and Tomei head gasket. She's now sealed up :)
One last time to admire the head before it gets all dirty
Sealed up, time to get everything else on before December. Because we all know how useless I become in December lol
  • Like 3
8 hours ago, admS15 said:
Edward would cum his pants lol
Can't wait to dose again, with an older GT style compressor wheel it will dose great ??
  • Like 3
Last night's efforts involved getting the timing kit on, checking all timing marks and getting the tension of the belt on correctly. Alternator and water pump ancillary belt on too!
Yes I know it's a Gates belt, part of me remembers I ordered a stock belt but after opening the package just the other week after a year it got me by surprise lol. Maybe the guys at 999 Automotive packed the wrong thing or I actually ordered the wrong kit, nevertheless it's on!
Brand new crank pulley on too, none of that fancy Ross business either. OEM should be good for the "stock" motor lol.
  • Like 3
17 minutes ago, GeeDog said:
Looking good. Where did you get the drip tray that fits over the engine stand - looks like a good idea.
I borrowed it from my mate haha.. I think he got the lot from Burson's
The quicker I get this shit box done, the quicker I can throw it on the dyno and start tuning it. Started to get the itch, thus the build thread is moving a bit faster.
Already altered my existing map for the new motor, predicting it would be a little laggier I've flattened the timing instead of ramping it once torque decays
nice bits...
the question is...will you be able to keep up with the ricecake at wakie.....
i'll be holding it flat through the kink with ~310kw m8...then hard on the brakes & hot into the first corner....powering out with the force of 1000 naprec's
  • Haha 1
Le Siet Bok never stands down a challenge, this heap of shit barge is made for the straights! *cough* Powercruise, Roll Racing, WSID lol
In seriousness, should be able to be competitive at Wakefield, hopefully dip into the 1m5s~6s with a proper driver.
  • Like 2
Man I'm getting tired of putting this croc of shit together. Constantly sleeping late, skipping gym and smelling like a degreaser meth lab lol.
Tonight's effort: cam baffle plates, half moons, cam covers, cas bracket and sealed up the sump.
I ended up with 2x 10mm dark bolts that have rounded ends after the thread finishes. Not too sure where they go lol.
  • Like 5
Looks mint. I have some spare rb25 covers (which have been gutted internally to fit a 26) that are perfect for putting in an engine so you dont mark your freshly painted ones... but looks like the new ones are permanently on!!!
5 hours ago, niZmO_Man said:
Isn't building an engine a workout anyway? :P Just dead lift the engine or squat with the head or something.
I've actually injured my back several months ago... these days I'm deadlifting what my missus does at the gym and it's a struggle :(
Great work on the engine.
Brb checking if mine still in car as this engine is looking way too similar :P
  • Haha 1
So close yet so far, typical NBNish delivery lol.. Over budget and project schedule blown out of the water.
Got the hot side on, then found out drain doesn't fit lol... Fine, eBay some dim sim goodness, should arrive soon.
Then go and fit the coldside, started to look good.. Then yep, just my luck all thr injector boss o-rings are cracked from prolong exposure in my tool box. Decided to Yolo and ordered 1550cc Bosch injectors, Plazmaman rail and now will remove the R33 plenum and fit the R34 NEO plenum instead, this means I no longer need any injector bosses. Another delay sigh...
Oh yeah these are the two bolts that came back with my head when I got it machined and tickled, anyone have any idea where it goes? Lol
  • Like 2
7 minutes ago, ActionDan said:
o-rings don't fit, nek minnit all new cold side lol
That's how the NBN is being rolled out lol
  • Like 1
  • Haha 1
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
