3 minutes ago, ActionDan said:
Looking good.
His wiring guy probably needs to learn how to use a ruler or go to Specsavers ??
Never ending saga with this car. Decided to get a decent coil kit, and surprise doesn't fit like a decent kit lol
1 hour ago, GTofuS-T said:
Looking at the first pic again, what was the actual issue? it all looks like it's plugged in and nice and neat compared to the latest pic...
the last coil pack has been turned around so it clears the covers, however you can see the last connector is too short hence the loom is compressed and sits stupid.
So did some last minute road tuning during the week and poured in E85 (because no idea how much timing the motor can take safely so used knock suppression fuel lol) and then took the shit box to a skid pad.
LOL... Was interesting to say, things to note:
  • a car setup for the track setup doesn't work on a skid pan very well :D
  • a big laggy turbo isn't great on a skid pan, comes on you spin out, clutch kick and you bog
  • can't slide around at 4k rpm in 2nd, it bogs, rev it harder and spins out once the turbo comes on (lag life)
  • semi slick tires on the rear not a great idea either (borrowed some drift tyres afterwards)
I'll upload some in car footage soon once. I pull I pull it down from my VIRB.
Even the seasoned drifters had a go and couldn't slide it properly in 2nd, mainly slid around in 1st lolol
  • Like 1
2 minutes ago, BakemonoRicer said:
Time for an EFR mate
More like time for a smaller sensible sized turbo if I want to play in this sport, but my heart lies in circuit racing, powercruise and roll racing.
Anyhow, not bad for a shake down. A few things I've noticed after yesterday:
  • I didn't seal the sump properly, there's a weep at the front (using a RWD sump on a AWD motor, doesn't seal well)
  • turbo is too big for drifting
  • should have bought a M235i BMW or a 335i BMW lol
  • Like 1
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
