Tier 4 engine bay, will be Tier 3.5 when it gets a new plenum and the cam cover hoses routed properly.
Going to powder coat all the parts soon, when I find someone (when I get off my arse)
  • Like 2
Tier 3 laundry nearly done, just need to adjust the doors, fit door pull tabs, hit it's mum with silicone, fit new taps/spout (whenever it comes) and gap fill and ready for roll racing.
  • Like 2
  • Haha 1
All the pro shops will be blown away by the build quality.
  • Like 1
Is it just the photo or are the panel gaps all f**ked in the two top right doors?
Need to adjust them Habib, wallah hasn't gone to the dyno yet - relaks
  • Haha 2
All the tuning shops will be mad, Nistune is pretty decent.
Your using Nistune for the frontloader?
Does is have enough hektic features, I was sure you would be running a Hellatek plug and play with the systems dash..... hows else you gonna know the RPM of the washer
Bro.. niztoons has laundry control and full flex detergent (3x sections for pre, wash, and post wash), and you can preselect RPM :)
  • Like 2
I want to see how well it goes when you do the cold water to atmosphere purge during summer to make sure you're getting the coldest possible water into that wash!
That spray will look hectiks!
Getting quicker and quicker at doing timing belts lol..
So car was weeping oil from the front main area, I initially thought I over packed the pump with grease and on it's first start up there was an air pocket that popped off the front main seal. Wasn't leaking too much, but enough to start forming droplets near the crank after a drive.
So thought today was the day to remove the lot and pop in a new front main seal, to my surprise it turned out to be lose oil pump bolts ???
Yep, RTV the sump, new oil pump but when I went to tightened up the lot the next day after the RTV dried up, I forgot about the oil pump.
Anyhow, tightened up it's mum, here's hoping it won't weep anymore lololol.
  • Like 1
Reminds me of the time my mate and I both thought the other had done up the front passenger calipers bolts when we'd had them off t paint them on my first 33.... until it came off at 60 and jammed the wheel to a sudden stop....
at least it stopped! lucky!
Real quick, complete with sparks from the wheel well.
As an early 20s NFI home mechanic, bricks were shat lol
Part of why I am so appreciated of SAU and did my own tutorials for it etc, the info I gained here allowed me to be a less shit mechanic.
Edited by ActionDan
  • Like 2
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
