Buying a new car isn't the be all and end all you think it is.
I still battle daily/weekly with buying another S14 for skids even though I have a perfectly capable albeit expensive skid car (f80 m3).
3 cars is probably already enough I don't need a 4th really....
That's true, however the creature comforts and all the tech aids in new cars make driving just so much more fun. Want smoke? press a button, want crackles? press a button, want firmer suspension? press a button.
Let's see, maybe once I hit up Wakefield again and chop a few GT-Rs I might be happy again.
Yeah but you just don't feel as engaged with the car.
Something that is a nice daily that you can take to the track is still going to be compromised.
Unless you are daily driving the 33 I don't see the point in changing it out.
1 hour ago, niZmO_Man said:
Depends on your definition of fun. Pressing a paddle and hearing farting noises vs. shifting gears yourself.
Yaasss!
This lol.
I must say, I didn't like the whole paddle shifter thing, but it grows on you. Press paddle and concentrate on next corner, it can be quite fun. Almost feels like you're driving the old Super Tourers with the sequential paddle boxes.
Yer I find I only ever use the paddles on down shifts for braking, very rarely on acceleration.
Generally off the lights its just gas it lol
But if I was going for a run up Macquarie pass or something like that, Ill use the paddles
Oh an only ever when the wife isn't in the car lol
  • Like 1
Was windy last week and my GTR boot and spoiler hit the pavement pretty hard and door toppled over onto the car.
A week later they're both in the same position lol.
  • Confused 1
  • Sad 1
A year later, decided to get off my arse and update the engine number, also the 1st time I've driven it in 3 or more weeks.
It's not slow aye? Got it a bit sideways then I stopped and thought, I really need to keep my license for work so gave it a few more hits now it's back in the backyard.
ummm.. not sure, it's covered in dents/rust - puts me off and I need to throw the Nissan idle control valve in the bin, and also the throttle body and go DBW.. The idle control reacts so slow and stalls sometimes with the AC on, I suspect it's filled with gunk and crap from 20 years of terrible air filters and engine blow by.
But that's money I don't want to spend and time I don't have to setup the DBW lol... so it stays how it is.
f**k the a.c. off, open a window.
#streetcar
  • Haha 1
#streetcar
Yeah it's Nissan, power window reg died on the LHS.. piece of shit doesn't go down
Rotated the wheels on the beast, man 20s aren't light. They're like 25kg per corner!
Dealer wanted to charge me $40+ for a wheel rotation during the $420 service, yeah nah.
Also, wheel bolts are torqued to 140nm not 100 ~ 110nm like wheel nuts.
Yes those are OEM lock bolts :)
20190922_100314.thumb.jpg.689ed2744f1f570e65e111ecc4130758.jpg20190922_103945.thumb.jpg.338eb33a666b0835145e487444bb2ecc.jpg
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
