Just now, jcAUSER said:
That is a lot of bloody cars between us all.
Just think of how much money we have all given the government on bloody stamp duty and transfers :(
Plz don't talk about that...
  • Like 2
4 minutes ago, ActionDan said:
Say what?
Waiiiiiiiiiiiiit.   I'm completely wrong here, I've assumed you're the same ActionDan who was on numerous NZ car forums and moved to Oz and is now on numerous Oz based forums - though now you said "Say what?" I notice you are in Vic, whereas he is in Perth.   Well f**k, all this time I've thought you were him ahhaha.
My bad.
Edited by Lithium
He sounds like a cool guy, cannot believe he stole my nickname though... it was given to me by my mates back when I used to be cool.
Who TF does he think he is...
Edited by ActionDan
Dan is a very powerful name.  I can only imagine what it'd be like to be an Action Dan.
  • Haha 1
29 minutes ago, Lithium said:
why did you get rid of the 40th anniversary?
Wanted to be sensible and buy an adult car, that didn't last long lol.
  • Like 1
What ! What ?
My skyline is not a sensible car ? ? ?
For shame !
Next you'll be tryin to tell me there's no Santa Clause !
I cant believe I forgot about this baby.
I may get stoned to death for this but any Ford Fans in here? More the old school bangers?
My dad has a 1980 XD ESP 351 Clevo that is a pre public sale FPV Management car. (My inheritance in the waiting lol) He has been offered some pretty big coin for it, but she aint for sale. :)
  • Like 3
Next car to setup and tune, 1JZ stock bottom with ARP studs, stock cams, and a GTX3076R Gen 2. Will be running flex fuel, and piles of boost.
Customer wants 300kW+ on 98RON and 400kW+ on E85. I did say to him you're running stock rod bolts, so we might have not overly push the setup. But let's see, starting the setup today - hope his wiring dude connected everything up properly, if not there's going to be 6 hours of swearing ahead.
  • Like 3
400+kw on that setup is going to involve swearing unless it's one of those builds where everything is actually setup correctly and it doesn't run out of fuel, spark, air, or things start popping off, getting too hot, or some combination above.
My bet is medium swearing and "We almost got there but one thing can't quite make it"
  • Haha 1
I bet his mates cousin read a facespace post about a 400kw one in Freedomland. Fudge air correction factor for the 400kw wank figure.
And yep, nothing ever gets handed over to me 100%
Poor owner, paid $4k for a wiring up job with issues.
I/Os were not configured, nor were they even in the god damn spreadsheet the wiring guy did, he simply just said work it out, it's not hard... ?‍♂️?‍♂️?‍♂️
Then came trying to setup the calibration table for the wideband, then found out the voltage received was wrong, took apart his dash and traced the wiring and guess what? The sensor ground wasn't connected to the wideband.
Anyhow, after all of that finally got everything setup and temporarily connected the wideband's sensor ground to the chassis to get some form of output into the analogue input of the ECU I find that the stepper motor for the idle control valve doesn't work. Just sent Haltech a support ticket to see if the wiring is correct, if so perhaps the idle stepper motor is toast. Ended up using rotational idle to control the car's idle lol.
5 hours later, took the car on its maiden voyage, 1 bar of boost and she moves ok. Just no power steering, no vehicle speed sensor to ECU (as the wiring guy said it's not needed, what the?), no idle control valve, slightly off AFR input to ECU (currently no O2 control), and a slight fuel leak on the return lol..
Man I hate modded cars even more!
Anyhow, Merry Christmas All!
#skidsvideocoming
  • 1 month later...
Long time no update, because there hasn't been an update.. but I did drive the car to work this week (thank god just once) because the wifey needed the car to see her sales team on a day where I also needed the car.
Anyhow, 1st time I drove the car in about 3 months - gosh it sucks in peak hour traffic to North Ryde LOL... not to mention the A/C causes the motor to stall when it comes on at low RPM, even with 20% additional DC on the IAC it's not enough. I suspect a cooked compressor and/or condenser (it is quite warped, looked like sometime ago it was in a light front ender).
Plans to fit the new A/C idler pulley - but at this rate I might as well swap out the A/C compressor.
Other than that, might buy a 100mm HDi GT2 core then tune the car once and for all, track it a few times, then strip sell :)
Unless.......... someone gives me 30k straight up and it's yours.
Did some work on the land boat, flushed the gearbox oil, lowered the front by another 8mm and replaced the AC idler.
Turns out I installed the original one incorrect so the belt was ever so slightly offset forward. On hard limiter bashing I assumed the belt would jump and hit the PS belt and throw it off.
Anyhow, regardless oId idler into the bin, new idler installed. Let's hope no more belts come flying off!
Hey Johnny;
I got two AC compressors in my garage, you can have, that only need the front bearings changed out if you need them.
Change out the bearing then swap out the compressor ! Might save you some time.
1 hour ago, PLYNX said:
Hey Johnny;
thanks Pete - but I probably won't get to this for a while (maybe never lol)
1 hour ago, ActionDan said:
And the noise?
I think it's gone, but I also have a stupid Gates timing belt which makes a whirring noise too (ordered OEM, opened the box a year later, came with a Gates belt)
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
