$850 later, ready for garage parking competition.
New seals, new bearings, added 2x shims, backlash reduced a bit.
Just need to redo the ABS wiring, sometime in the past (not during my ownership) someone cut the plug and rejoined it poorly. When I put in the 2 way centre I never bothered to fix it because the mindset was "cheap track car, don't care". Fast forward 7 years or so it's not a very cheap track car anymore ?
  • Like 1
4 hours ago, ActionDan said:
As if not keep it for your next nugget track day special
He's all about Don Mega spec with Samsonas now.
  • Haha 2
11 minutes ago, ActionDan said:
Given the price, you gonna lash out and just go new?
Would be a sensible approach, however when you think about it.. most 350/370Z don't produce very much power. Given that assumption, you would think the boxes are less thrashed than a Skyline box.
Kind of how you would compare a high class escort to a hooker around the bowlos.
1 hour ago, ActionDan said:
I got 2 updates in 2 threads, both posts from you, both posts banging on about Samsonas...
Do you get a commission or what?
I wish :(
On 8/24/2020 at 12:50 PM, Dose Pipe Sutututu said:
Imagine I did, just imagine that!
But reality, this non-Don Mega Ham build will probably just end up with a 350Z CD009 box.
fisch automotive are making RB conversion bellhousings for CD boxes at the moment, im very interested
  • Like 1
Someone should do DQ250/381/500 conversion bellhousing for RB's.
I feel it'll go well with AK47/crackle maps.
Nailed it, I'll take the DQ500 thanks.
If the one in the boat falls out, just pull it out from the missus' Tiguan and I'll be good again.
  • Like 1
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
