i recently threw out the 45 degree frame i had for my old 12 panel system you could of had :(
Soume guy gave me $200 buck for it , was supposed to come pick it up about 2 years ago and never did lol
so it went in the metal recycling bin.
  • Sad 1
On 09/07/2021 at 1:21 PM, ActionDan said:
Hmm would I get much for some aluminium RHS???
nar i called the local metal recycler and they said unless i have like 50 plus kg they were not interested.
so put it on facebook market place lol
  • Like 1
On 09/07/2021 at 12:44 PM, ActionDan said:
You can DIY a tilt adjustment easily enough.
I have a big set of adjustable aluminium legs sitting in my shed doing nothing, kept them for the materials alone.
I didn't need them as my roof pitch is bang on for my locale.
Also these babies arrived.
No description available.
party time, I want to see your graphs lol
On 09/07/2021 at 9:30 PM, Ben C34 said:
Area under the curve f**kers
Not in our experience. In our current place we need to optimise for morning sun in winter (heater) and afternoon (AC) in summer. Pretty much all year round in the middle of the day to mid afternoon the battery is full and we are getting 5c to export which is a waste of time
  • Like 1
Yep batteries change desired usage and output patterns a bit.
My china inverter (MPP) on the off grid has stopped giving me output from both MPPTs, only showing one currently (global issue with them it seems on the cloud platform) so charts aren't as helpful as it only shows 1 array.
I can get the days total output off the inverter though so I expect it to go from like 6kwh on a nice sunny day to maybe 8-9 hopefully.
The on grid system is only giving me like 7-8 on a good day before the shade kills it. I hope to get another couple kWh from that after I remove the tree.
All my stuff is mostly north - west facing so it all suffers in winter here being up on the hill where the sun is gone very early.
Summer for the on grid is like 20-24 before shade kills it, ok for a 7-8yr old system,l I think.
Off grid will do better but I haven't had it through summer yet.
Edited by ActionDan
  • Like 1
Started fitting optimisers, 3 down, 15 to go. Fiddly job to do neatly and keep cables up and out of the way/weather/off roof etc. Would be easier if being done before panels were fitting.
Connected 1 and turned everything back on to make sure it worked first.
Nothing blew up, didn't die.
Stay tuned.
  • Like 2
Stay tuned.
Should be interesting to see the yield increase!
My mate recently got a solar system also installed at his place, albeit on two different roof sections with different pitches. His panels however do face North. You would think because of this he would yield less compared to a North facing house with a flat roof (all panels get East/West sun all day), but everyday he is consistently getting 5kWh more than I am.  Geographically we are about 10km apart and his house is west facing.
We both have 17x 390W JA Solar panels, but he is running a Fronius 5kW inverter where as I'm running a GoodWe one.
See how we go, I just put 4 more in, leaving 2 to go on that array and the 9 still to go on the other array.
Given my shading I am expecting a gain but do not have good graphical data to compare only my anecdotal monitoring.
That said, the panels will be happier as the bypass diodes won't be getting worked so hard given the shading I get in winter months.
  • Like 1
Went through my old Go Pro to delete shit and found this gem!
Terrible driving, street tyres, Bilstein/King Spring suspension setup and dose :D
  • Like 7
On 05/08/2021 at 11:43 AM, Jasoncauser said:
what tyres where you running then? a little loose onto the main straight :)
If I recall they were just Nitto NT05 tyres all round - nothing flash. It did have ~320kW LOL
  • Haha 1
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
