  • 3 weeks later...
Man haven't done a house update aye, so here's a good find.
Brand new house, blah blah blah. I went to change a light switch and I found these Easter eggs (many, actually all the light switches were like this).
Brills.... anyhow ordered a bunch of screw connectors to fix up this fcvk up. Building industry, full of cnvts.
  • Confused 1
  • Sad 1
WTF Johnny, real deadbeats not even bluepointing - Only serious fkwits bother to pull the neutral and earth to the switch anyway as there is no point.
Loop at light ya dumb karnts.
  • Sad 1
It's at every single light switch too! Trust me, I wasn't very happy seeing the level of horseshit wiring, but this is what you get buying a brand new house off a property developer.
Saving $0.13 per screw connector is top priority for some it seems.
  • Sad 1
I see a neutral and earth down a wall on a lighting circuit for no reason I lose my shit - it screams amateur. I thought only Qld did that rubbish wiring concept.
No BP's on connections ? That's just not even remotely reliable or safe is it.
Seriously though, I would be finding out the electrical contractors licence number for who signed off on the CoC for bullshit like that.
Assume it's just a terminology difference, but what is blue pointing?
If all you've got is twin core + earth, surely you're not stripping out the active just to avoid pulling the N and E down?
Genuinely curious, not taking the piss.
Generally you use twin core from the light source down to the switch to break the circuit, all other places we've been at have been like this.
This is the first time I've seen A/N/E at the light switch.
Disclaimer: I'm not a sparky by trade but I've done electrical engineer courses during my IT course at uni for fun. Also I probably do neater and more reliable wiring than most sparkies, alarm installers and trailer experts lol.
I've got the entire OC document deck when I bought the house, the sparky signed off his on work (self certified) and a private certified signed off on the lot for the OC.
I am tempted to take further action - however what will that result in? just more headaches, heaps of random people going in/out of my house disturbing my wife and kid. So, weighed out that cluster f**k and replaced all the shitty solder/tape jobs with screw down connectors and trimmed wires to length then called it a day.
  • Like 1
Same, not a sparky, but done a fair bit of bits and pieces as you know.
Have seen tons of light switch's with Twin + Earth BUT using screw connectors even if the joins are soldered.
Tape is a bit rough lol
  • Like 1
If didn't care about being compliant, etc. I would have crimp and dual wall heatshrunk the lot lol... but need to stick to standards to avoid issues in future.
BP, bluepoint etc old sparkle terminology for insulated screw connectors.
Regarding lighting circuits, it's generally discouraged to run the neutral and earth down walls with your hard active and then switch your hard active at the switch. Doing it this way means you never have a hard active at the light fitting, only a switched active.
This is very annoying when having to modify circuits as you have to get down a wall to retrieve a hard active, instead of being able to pick it up in the ceiling. Getting down some walls is a nightmare, sometimes downright impossible without major wall destruction.
So better practice is to generally run hard active to the light fittings and only run twin switch cable to switches - less cables down walls, no neutral or earth connections hidden behind switch plates, always have hard active at accessible locations, no risk of neutrals or earth conductors anywhere near exposed actives
As to running the cable because you only have twin and earth instead of just twin switch cable is a bit of a cop out. Don't have twin, go buy some. 1.5mm twin and SDI is something that anyone doing wiring, like an A grade electrical fitter / mechanic, never doesn't have.
That's it. Not all A grade electricians have an electrical contractors license and contractors license is the only way to issue an electrical certificate of compliance. You should have one of these:
On 27/09/2021 at 9:54 AM, ActionDan said:
You have already stuffed it by touching it yourself technically ;)
I would certainly never do anything like that.
  • Like 2
That is some real fked up shits. But sadly quite common these days. IMO basically anyone working on a house (like cars) is dodgy unless proven otherwise (and how can you even do that).
  • Like 1
Yep pretty much this!
Oh wells at least one thing sorted and I also installed the Google Nest smoke & CO alarm too! Might get another one for upstairs.
After that, will think about some home automation - do have a few of the Arlec Grid connect bulbs I use in the staircase & garage lights but might go with all the lights in the house at some stage too.
On 01/10/2021 at 3:51 PM, niZmO_Man said:
Interesting however those switches need an Ethernet run to them.
https://www.lifx.com.au/products/smart-switch-4-gang
The above runs off WiFi and conveniently I already have A/N/E where the switches are LOL.
  • Haha 1
The final piece before 1st start 😎
ATI don't have an off the shelf RB25DET balancer, so HiOctane made a pulley to fit.
Might even start the car today 🚤
(Yes radiator isolating rubbers will be installed lol)
  • Like 3
Tried to start the car, starter motor died LOL...
Starter was moving super slow, we tried adding a jumper pack, starter motor got ripping hot and then it stopped moving completely and just clicked only lol.
Waiting for a reconditioned one now :D
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
