On 04/01/2022 at 9:43 AM, Kinkstaah said:
LMCT+ sale when
Imagine that, would totally take it and walk straight into a BMW dealer
On 1/4/2022 at 10:05 AM, ActionDan said:
oh f**k here we go again... ;)
On 1/4/2022 at 6:43 PM, admS15 said:
M2 comp is my vote
Got a colour preference or you maybe get the M3 to fit the family
I would go a boring run of the mill colour such as the one below. Don't need to wash it often, can get dirty and won't look dirty. Also would rock those stupid oversized Euro plates too to cover up the stupid front bar.
However, the thought of a M340i is making me more horny.
AWD, B58 platform, ZF box (ticking many boxes here)
On 1/5/2022 at 10:40 AM, Dose Pipe Sutututu said:
TBH I think the R33 GTS-t is uglier
Its amazing how ingrained these views get when you look at your car everyday and it's no longer unique to you. It doesn't take long at all for people to look at Skylines (for example) and get used to how they look and to them it's nothing special.
But to someone else who hasn't seen them before (or sees very rarely) they are OMGWTFBBQ good looking etc.
This could happen even if you have a F40 parked in your driveway.
I purposely made mine blend it and boring looking so it wouldn't stand out, last thing I want is attention.
It's not even low, it's probably in the top 10% of the world's highest R33s LOL
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
