On 04/01/2022 at 9:43 AM, Kinkstaah said:
LMCT+ sale when
Imagine that, would totally take it and walk straight into a BMW dealer
On 1/4/2022 at 10:05 AM, ActionDan said:
oh f**k here we go again... ;)
On 1/4/2022 at 6:43 PM, admS15 said:
M2 comp is my vote
Got a colour preference or you maybe get the M3 to fit the family
I would go a boring run of the mill colour such as the one below. Don't need to wash it often, can get dirty and won't look dirty. Also would rock those stupid oversized Euro plates too to cover up the stupid front bar.
However, the thought of a M340i is making me more horny.
AWD, B58 platform, ZF box (ticking many boxes here)
On 1/5/2022 at 10:40 AM, Dose Pipe Sutututu said:
TBH I think the R33 GTS-t is uglier
Its amazing how ingrained these views get when you look at your car everyday and it's no longer unique to you. It doesn't take long at all for people to look at Skylines (for example) and get used to how they look and to them it's nothing special.
But to someone else who hasn't seen them before (or sees very rarely) they are OMGWTFBBQ good looking etc.
This could happen even if you have a F40 parked in your driveway.
I purposely made mine blend it and boring looking so it wouldn't stand out, last thing I want is attention.
It's not even low, it's probably in the top 10% of the world's highest R33s LOL
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
