On 22/02/2022 at 4:04 PM, niZmO_Man said:
yeah try finding parts for a GT-R
anything on EFI Solution site? I can help you with that.
BTW... I might have been told Haltech Elite will be supporting canbus keypads and they have a test version working on the bench. I may or may not have heard that :)
@r32-25t unwire all your old school switches eating up your AVIs, time to get a canbus keypad :D
keypad - Haltech
  • Like 2
keypad - Haltech
I don’t have any switches on the AVIs, I’ve used them all on sensors and need a few more
Remember to use your old afm inputs if you haven't already - there is another 2 AVIs doing nothing otherwise.
  • Like 1
haha, already went there, even used the 2x narrow band inputs too.. I went to town.
No more spare inputs :D
Ive grabbed them and the original O2 sensors
  • Like 1
Same. Don't have Emap but have Exhaust temp.
  • Like 1
On 22/02/2022 at 5:08 PM, r32-25t said:
thats my list and to that I’d still like to add fuel temp and maybe a trim switch which jem have managed to make work with the eboost2
You have flex sensor on an spi yes ? Fuel temp is incorporated into that - no avi required.
  • Like 1
Depends on sensor too, some seem to not send back fuel temp however all the new smaller/compact Continental ones I've setup seem to.
Yeah it’s on that but it’s an older one and I’m not sure if it does temp
Might need to switch it then. From what I've seen the Haltech, VDO, Continental, AC delco and GM ones with the 3 mounting holes measure fuel temp - they all seem to be the same thing if it looks like this. I have a genuine Haltech one on the blue 32 and the white 32 has a VDO one with shorter pipes but same body;
If it is like this below I'm not sure - probably doesn't but I have no experience with them to confirm:
keypad - Haltech
Bit late to the party mate with that.
Haltech have been really adding heaps of stuff lately with this NSP update.
Still waiting on the Mexico trip video........
  • Haha 1
I’ve got the haltech one with the 3 bolt holes so I guess it does it, one less AVI that I need now
  • Like 1
just be sure to select this when configuring the input
And if you really want your fuelling to be spot on, make sure you build out your fuel density table. Most tuners don't bother with this and just rely on the static value density that is default on the Haltech. You really need density vs. fuel temperature to have accurate fuelling. Car idles so much better now with this table defined, also with DBW sure makes A/C, big cams and idle a walk in the park.
  • Like 1
Adam at JEM setup my trim switch to the eBoost settings and also to boost by gear as it’s auto. It works really well
  • Like 1
I saw a video of it and he was talking to me about it when I was there about 6 months ago. If I decide to put an expansion box on it I’ll get it all set up
Forget about the eBoost, 4 port solenoid and canbus keypad.
Have buttons called 400kW, 500kW, 600kW, Rolling A/L, Launch Control, etc.
:D
:D
Mines a dad wagon. I need better names. Wife, Kids, No Kids, Noisy Button etc
  • Haha 3
So this should work
  • Haha 2
Walked in, walked out $550 poorer.
I now have new bonnet/hood insulation 😂
Amayama couldn't source one, Kudos couldn't either, even tried EFI Solutions but somehow Skyline Spares could so yeah, sent it and bought it.
This is more expensive than a coacine addiction.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
