On 7/15/2022 at 5:03 PM, Dose Pipe Sutututu said:
Once you go DBW, you don't look back. Great idle quality, AC doesn't cause idle quality to degrade.
The factory air leak valves are so slow to react, with bigger cams your motor is very inefficient at lower RPMs the compressor engaging is enough to stall the motor.
Nissan should have used stepper motors like JZs or 4Gs, instead they installed a two slow reacting air leak valves lol.
Have you seen the rats nest of hoses under the intake manifold of an RB26? Stepper motors for idle control is far too elegant. On the bright side at least the power steering idle up on these motors isn't a physical valve that can start leaking power steering fluid into the intake with age.
  • Haha 1
On 15/7/2022 at 11:12 PM, Dose Pipe Sutututu said:
Used up everyone single DPI, AVI. Even sacrificed the power steering input lol.
DBW uses up 4x inputs.
How many extra i/o’s does if use.
The fact they fitted 2 of them always confused me
Drive by wire uses 4 AVIs and the 2 dbw driver wires
brake and clutch pedal use one each
  • Like 1
  • Thanks 1
Thanks Looks like I’ll need an i/o expander. May as well get a can button panel as well. No clutch pedal on mine. So I saved one there
To free up some AVIs you can cheat with the temperature sensors and use them on SPIs and change the scaling of the sensor to suit
the drive by wire AVIs must be on the ecu and can’t be in the i/o box
  • Like 1
On 7/16/2022 at 12:27 PM, r32-25t said:
Did you not already fit a brake pedal input when going to dbw as fail safe if something goes to shit?
Is that even a thing?
I’ll have to move some other stuff to the I/o box then. Probably auto controls
On 7/16/2022 at 1:05 PM, RBW49N said:
Try doing a brake job in a modern car with a factory ecu
That's a different story.
In relation to aftermarket ecus with dbw I have never seen them need a brake pedal input as part of the safety system.
  • Like 1
When you select drive by wire in the haltech ecu it pushes you to set up a brake pedal input so that if the pedal says be closed and the brake pedal is saying you want to stop but the throttle isn’t closed it will put it straight into limp mode
Interesting. Link ecus definitely dont do that, nor do motec from my experience.
it deosnt make sense, because all that matters is the pedal and the throttle relationship. If the pedal is lifted and the throttle is still open it should go to safety conditions straight away, regardless if you push the brake or not. Can't see how it helps at all.
Also I am assuming you mean  a mismatch between the pedal and throttle and foot on the brake makes it go into safety mode, otherwise you wouldn't be able to do burnouts and that would be dumb!
Anyway I looked it up and it is optional to have the brake pedal as part of dbw safety with Haltech, and it doesnt relate to a failsafe function really anyway compared to having to have a primary and secondary position sensor on both Pedal and throttle.
Brake Pedal Check  Enable if a Brake Pedal Switch has been wired and configured. Enabling this function will enable the Max Brake TPS Setting. This setting will override all other commanded throttle values.
From
https://support.haltech.com/portal/en/kb/articles/drive-by-wire-elite
can't see why anyone would actually do it.
  • Like 1
The brake input is optional on the Haltech, I personally don't use the brake input.
I'll post up my IO assignment tonight, unfortunately using SPI for temperature sensors are not recommended as you lose resolution.
  • Like 1
On 7/16/2022 at 4:36 PM, r32-25t said:
I hooked up both my brake and clutch pedals into the ecu all my temp sensors are on AVI except fuel
So are you using a lower throttle plate max opening with brake pressed?
On 16/7/2022 at 5:25 PM, Duncan said:
using a brake pedal override seems like a nightmare for left foot braking/trail braking, and burnouts for that matter
Sounds like a great excuse to have a “hoon” “race” button on the CAN keypad
  • Haha 1
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
