On 26/10/2022 at 7:12 PM, niZmO_Man said:
Don't worry, in 10 years' time you'll be glad you kept your $150k R33
Straight swap for gravitating BMW
Tonight's activities, trying to fix the ABS.
New relay in and nope, still have an ABS light. Will check fuses next, followed by sensors then ABS computer. If all else fails, will retrofit a new ABS system (yeah nah, jk).
Then made the car appear a bit more legal(?) Lol... Factory 18s officer.
  • Like 5
On 17/10/2022 at 9:55 AM, BK said:
You use a link right ? The link you can reassign the cam signal cable to actually be the crank reference signal. On an Elite you can't as it is a fixed pin on the ECU, so they were sending them out preconfigured for link wiring on cas wiring pins 1 and 3.
Yes a reluctor generates its own voltage. Can't believe Haltech told you to supply it 5v !
From what I can see the neg reluctor side needs to be pinned to ground and the pos side signal output pinned to the Elite TRIGGER +, so on a cas loom that would be the 2 outside pins 1 and 4.
The way NZ wiring is sending them out appears that they are pinning the signal to the HOME + which will never work on an Elite unless you swap the pins at the ECU end which you don't need to do.
Got my NZ wiring cam trigger today and got it working on the white 32.
FYI what I posted above is correct to work on the Elite. Pin the reluctor to the 2 outside pins using signal ground and crank trigger +, no ecu repining required.
  • Like 2
Nice, you'll notice you'll have less trigger count errors at higher RPM compared to the OEM Nissan CAS.
I updated my post on the Kebabtech forums too. Funnily enough someone also PMed me on the Kebabtech forums asking for help regarding the NZ Wiring Cam trigger too.
I still would much prefer the proper Ross crank trigger setup I have on the blue 32 with DC powered hall effect sensors though - can't beat measuring the crank position from the actual crankshaft.
I sort of winged it with the trigger arming voltages, something you don't have to worry about with the hall effect sensors. Might have to have a look back at your voltage table for comparison, but I gotta say so far so good. The timing light is not jittery like a cas and is rock solid, so without going proper crank trigger these definitely seem like the next best thing especially for the price.
  • Like 1
Of course, nothing beats a crank trigger.
However this is decent for low powered RBs (sub 500kW is considered low power these days lololol).
I might look into a stronger timing belt to avoid belt stretch. Currently just has an OEM belt in there.
I had Gates racing in both 32s but as everyone knows they are a pretty noisy belt. Still running gates in the white 32 but changed to a Nismo in the blue 32, sounds like oem in comparison. In my 33 I'm using a Power enterprise belt which also sounds like oem.
The issue with gates belts seems to be the nylon glass chord construction making them very stiff, whereas the Nismo, Power enterprise, HKS etc. have a high kevlar count in their construction making them very flexible and therefore sound less whirry.
  • Like 1
Maybe Gates, but I am judging that purely based off of their stiffness. Maybe I am talking out of my arse too because Nismo and the like would not use kevlar for no reason, as it has a higher tensile strength than steel. I think I'll be stuck in the Nismo or Power enterprise belt camp.
I'm surprised you can hear a properly tensioned timing belt over the fan and injectors, gates or not. I run the gates one in the race car and can't hear it at all. Obviously they would get noisier between the belt and idler/tensioner bearings if over tensioned
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
