6 hours ago, Dose Pipe Sutututu said:
Add it to your list of things to do 😂
More than happy to explain it and take you through it, alternatively you could use a PDM and double up outputs to allow 50A loads.
I went down this route because I set it up years ago before PDMs were a common thing.
Been meaning to tidy it up for years, and install a 2nd SSR. Found the time to do it now, since I'm not working (on paternity leave). It's amazing how motivated I am now because I'm not working my normal job. It's like my corporate job drains my soul of everything else.
Today, finished off the wiring from SSR to fuel pumps, I integrated fly back diodes into the wiring for sex appeal, instead of running them externally over the surge terminals.
It's a long list....  😅
Yeah definitely looks a lot neater than across the terminals,  good job!  You should start your own little Asian sweatshop now you're pumping out the kids and off work.  Get the kids swinging off the soldering iron bangin out custom PWM setups for Skylines! 🤣
LOLOLOL brah, there's no solder in that setup 🙂
Watching too many HP Academy videos and reading up on the Motorsport Wiring page on Facebook.
Would be nice if I could use the kids to build stuff I could sell, works for me 😂
  • Haha 2
It is good to stay away from solder, particularly in track use, as the vibration and heat from the soldering can break adjacent wires.
You won't find any solder in a factory harness, even back to the mid 80s
30 minutes ago, niZmO_Man said:
sounds like you need a bigger TV :P
LOL.. I do not, I wanted a smaller one and my wife said let's go a size up.
  • Haha 2
as the bishop said to the actress
Today, unboxed a box of new random shit I've collected over the years.
Fitted up new window stabilisers, as the old ones (most likely from factory) have worn down to the metal and ate the tint.
This also means I'll be getting the car re-tinted. Booked in next week for tint removal and re-tint in legal ceramic tint. The current one is stupid dark and also has started to go purple.
  • Like 1
Also re-fitted up infant seat mounts, this required me to attack those pretty speakers with a Dremel to allow the brackets to fit nicely against the car.
FB and wreckers wanted $50 for these brackets, I ended up buying them new for the same price from:
https://rawsparts.com/nissan_skyline_r33/98-r33-gtr-cra-kit.html
Bah. Who needs tweeters in the parcel shelf anyway? I don't even have full range speakers in the shelf. Just 6.5" woofers suited to infinite baffle or very large enclosure. Driven from subwoofer output, no shitty treble.
Sound stage in my car is 100% from the front. Much better imaging.
@GTSBoy those speakers have the gain on quite low, merely there for fill and the odd time I drive around with no sub in the boot it adds a bit of bass back into the system when I turn off the high pass.
Also, if anyone has a keen eye, those are Jaycar Response Kevlar speakers from the early 2000s.
Agreed rear speakers are useless, however I had them lying around in a box for nearly two decades so slapped them in when I removed the ghastly horrible 6x9s the previous owner put in back then.
Front stage has (also discontinued ancient stock) Jaycar Vifa 6.5" with Ribbon Tweeters, a bit harsh for my liking so (maybe or never) might replace with a pair of Morel Maximo if I feel like donating more money to the car vortex lol.
1 minute ago, Duncan said:
Autosalon, my favourite car event. So classy.
Could have at least polished some of the scratches out!
  • Haha 2
 I ended up tearing up my same vintage kevlar Response drivers in the front doors, after one got wet and corroded the voice coil area. Had to make up these bad boys to replace the flimsy masonite panels that had been in there for years. Still running the Response dome tweeters and crossovers against these. Sounds great. The extra work put into the mounting baffle and sealing were worth the....very large number of hours spent getting them right. I think the baffle is 16mm thick, so it needed a lot of shaping to fit under the trims.
Edited by GTSBoy
  • Like 2
@GTSBoy very nicely done, you also have too much time LOL.
My old white R33 had Focal 165K2 and I sandwiched 2x 16mm MDF sheets together and made something similar followed by painting them both in sound deadening. Door proceeded to get 2x layers of eDead (Dynamat knock off at the time).
This car, the fronts have had the stock plastic mounts attacked with a Dremel lol. I think I might get in touch with @Fhrx (hope you're still around Marty) to do my front stage and make a nice slim enclosure for a sub in the boot that also covers up all the SSR shit and surge tank lines.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
