On 23/05/2023 at 8:37 PM, Dose Pipe Sutututu said:
Honda vibes 😎
Can't beat em, join em ay.
I saw a clip today of a civic with a k20 running 126psi boost, compound setup. Yep that's right 126psi. Freakin Honda's.
I think you need to crank that boost some more 😂
  • Haha 1
On 30/05/2023 at 11:21 PM, Kinkstaah said:
"Babe I want to run 126psi on your daily in the driveway, a guy on the internet said it was fine"
(fn2r good car do agree)
Please post video of said Honda exploding or Mrs kinkstaah wacking you across the head, 😂.
  • Haha 1
  • 4 weeks later...
1 hour ago, 34GeeTeeTee said:
This thread needs moar update!
Sure thing!
So throwing around ideas with MCA's tech support and @34GeeTeeTee and we all agreed that I needed to bump up the spring rate at the front of the car, especially with it now predominantly being used at SMSP.
Handling wise, it is somewhat quite neutral and does what I command, however on hard braking it does tend to pitch forward quite a bit and cause the rear end to unsettle. Not what you want on a fast track like SMSP.
So yeah, going from 10kg/mm now to 13kg/mm. Will then set the front anti roll bar onto the softest setting (should have just kept the stock one to be honest. Whiteline and their marketing team are great at what they do, market things.)
(My personal opinion) it's better to adjust body roll with spring rate & dampers and only use anti roll bars to fine tune how the car rotates. They shouldn't be the primary device to improve handling.
Anyhow, turns out Matt had a set of 13kg/mm he didn't need so I took them off his hands (thanks brah). They have been sitting at the same spot for the past 2 weeks lol.
I have another track night booked 11th of July, better get off my arse lol.
7 minutes ago, ActionDan said:
I had similar issues with sway bar tuning and ended up backing them right off/swapping to stock bars from other cars etc.
Yeah, Whiteline are great at marketing things you don't need.
I fell for the whole get the front and rear anti roll bar package bullshit (incorrectly called sway bars) theory, just made the car twitchy as shit!
Especially when you're going hard into a corner and there's not enough spring rate and you bounce off the bump stops then you're off the track!
That's exactly what happened to me, the car would oscillate uncontrollably, dangerous AF.
It's gotta be part of a full package. I'll be starting from scratch with the Silvia given I will be using slicks or much wider R comps this time around.
  • Like 1
I think you will find Whiteline also agree with you though...
I am with you regarding the car pitching under braking, though that is still going to happen and won't just stop doing it even if you have no front suspension. Momentum is momentum.... a better driver than me would use this weight distribution to assist with turn in, which is what trail braking is all about.
Also don't slam the brakes on hard then immediately turn etc, ease in/out of the brake pedal to let suspension do suspension things. All easier said than done when approaching T1 SMSP or T1 Phillip Island or T1/T6 Sandown
  • Like 1
Have a look at what your rear wheels do under braking. When I did my suspension setup however moons ago, the rear was toeing out under brakes making the car farken scary and quite unpredictable.
Assuming the HICAS is locked out (as we all know it should be because it’s junk), the movement of the lockout bar 10mm up and 10mm out fixed it.
I have the report somewhere. Could flick it to you if you’d like.
  • Like 1
properly adjusted front upper links at the rear can help with that bump steer too, adjustable arms are often installed there but not adjusted properly (because it takes some time)
  • Like 1
@Kinkstaah I'm by all means no Max Verstappen or Checo Perez, I'm just an Asian that drives better than most Asians 😂
T1 I'm ok at SMSP, it's T2 and T8 I'm feeling the effects of the pitch and have actually bounced off the bump stops (smashing the brakes doesn't help either lol).
@Piggaz I've actually shifted my entire subframe closer to the body, the LCAs now point downwards (closer to OEM geometry) and the entire HICAS junk, including the ball joints have been all deleted. I used to run total 4mm toe in to combat the toe out on squat, however now I don't need to, so it only has 2mm toe in.
@Duncan I've extended the traction rods by 15mm, which has reduced the car kicking out when power is put down around a turn. Somewhat I don't have an issue with traction or the car kicking out sideways like 95% of the RWD Nissans you see. It just hooks and takes off, even with street tyres and 437kW at the back.
The main "issue", if you even want to call it an issue, is the pitching due to the weight shift. At Wakefield it didn't seem to be much of a problem, but at SMSP you really notice it as you're going into turns at greater speeds
@ActionDan been waiting for more development on your car! Yeah I've been following that Track Racer Australia group, good learnings from them too.
T1 may not be so bad cause I doubt people are slamming 100% brake pressure into the ground approaching it at the very last second, so the it may be benefitting from being less severe on the pedal by way of it being a fast corner.
My Sandown foibles are around it being a not-very-fast corner, over tons of bumps, at the end of a very long straight. Back end wandering around is less suitable. I am also very not-fast there (or anywhere). But I can see where going faster requires and like you say, rear end wandering around makes me think "nah, f**k that" which is not confidence inspiring if you want to also go quicker!
I found that using a BM57 really helped with this as it actually engaged my front brakes first so when it locked, it locked up the front, not the back. I don't know without looking if you have an upgraded front BBK. If you do, upgrade your BMC. Before I changed it, I was going through rear pads at 3x the rate of the front ones, on the same compound.
That said, racecars often have more brake bias at the back, because you want braking on all 4 corners to stop the car which actually helps it be more stable too 😛
But the secret to smooth driving and confidence is smooth inputs. Especially with what is a heavy car (any road car). Hell, driving fast is really just dancing around with weight transfer, so if you imagine dancing around with a 1500KG jug of water sloshing around, Takumi style - That's the game.
  • Like 1
I find the swaybars (ARB's or whatever...) are good with a softer setup like the bilstien shocks and springs but when running a true adjustable coilover, standard ARB's are the way to go, speaking from personal experience...
  • Like 1
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
