Advan ad08r great dry performance. Better than you would expect given the amount of tread they have wet weather performance.
In the same category as the re003 is also the hankook rs3
I have the 595 rsrr at the moment, but they have some incredible road noise, good grip and cheap, but you don't want to be cruising down highways/motorways on them.
I run a 255/40/r18 ad08r on the front and a 315/30/r18 Nt01 on the rear. Probably the most expensive combination you could get hahaha but I can't fault the setup.
I have a partially stripped out s13 widebody with a 460whp rb25 with full rollcage, solid bushes on everything, 15 body braces as well as big whiteline swaybars and obviously coilovers to top it all off...
so I'm super light and super stiff...
Traction has always been an issue but since running this setup for the last few months I couldn't be happier with how the car sticks to the road...
NT01 isn't really a street tyre, it is in fact barely legal as there's about 2mm of tread before it hits the indicator (well the 1st indicator). I run them on my car however it's 80% track 20% street use so I don't mind the useless wet weather grip and the crazy amounts of road noise.
For a decent set of street tyres I would look at Nitto's INVO range or Bridgestone RE003.
  • Like 1
  • 4 weeks later...
24 minutes ago, Hadouken said:
Where in aus can you get them?
Unfortunately you can't yet.. They came on my car from Japan.. I've emailed Bridgestone Australia and they said the tyre would become available to our market this year... Patiently waiting..
On ‎13‎/‎01‎/‎2017 at 9:20 PM, vxsr33 said:
I ended up getting rs3's all round in 235/45/17. Very happy with them, the grip and turn in response is amazing and i found them to be good in the wet too.
they are good hey. Have them on the front at the moment in the same size as you, and will do them on the rear too as soon as current tyres wear out.
For me to date though, the ultimate performance street tyre is still the RSRR. Just bloody awesome. Quick wearing but also relatively 'dirt cheap' on the performance scale. I imagine the ad08 might be better still but more $$, and not used them myself.
On ‎14‎/‎12‎/‎2016 at 2:53 PM, Anfanee said:
Apparently the new Michelin Pilot Sport 4's are brilliant.
I also hear great things about these; only thing the tyre shop pointed out, is they're not made for' performance' driving, eg not made with large shoulder blocks...so apparently will be good but just wear fairly quickly if pushed.
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
