Lowering GTT Coupe / Coils & Springs
Alright gents, I need some genuine advice on something that must've been covered 1,000 times and I'm still hearing two arguments after doing some reading for the past two hours.
Objective: lower my stock R34 GT-T to maximum legal limit (legit, it's like a patrol at the moment)
Budget: $800-$1000 including install
Want: lowered look with comfort but not wanting race-quality stuff. Car is a daily and I do a lot of highway driving
Conflict: springs are cheap and will lower to what I want but will kill my shocks. Coilovers are great but don't necessarily want to spend 2k on suspension just for a daily
Really really unsure which way to go here, but I see a ton of lowered 33's around my town and they all go springs/shocks and have no complaints. I'm smart enough to know that the poor man pays twice so I need some suggestions with the above information.
Is there an in the middle option between spending bugger all on lowered springs to achieve what I want then getting smashed around and paying later for it, and entry level coilovers that'll probably do things I don't necessaryily need them to do? Thoughts?
https://www.sau.com.au/forums/topic/468278-lowering-gtt-coupe-coils-springs/
If you just want it a little lower for looks, have a small budget, and aren't taking it racing, just put in lowering springs.
It won't "kill" your shocks, they just won't be matched perfectly to the springs anymore.....although in any case since it left the factory the springs will have sagged and the shocks will be slowly dying just from age so they aren't exactly what nissan intended any more anyway
Kings or Lovells or just about any equivalent coil springs.  Easy.
Best choice for dampers is a set of Bilstein B6s, especially if bought from SydneyKid as he sets them up to suit Skylines fairly well.  But....this will blow the budget, as the dampers are >$1k on their own.
So, read the damper thread again,
and then decide if you're happy to compromise on price and buy something that has twin tube innards, or if you want to stretch a bit more money for something single tube.  Your options include KYB and even some of the lower end Bilsteins.  It is my firm opinion that there has never been a decent damper manufactured here in Australia, so do not be tempted by Monroe, or Gabriel, even though they're probably no longer made here anyway.  Cheap shit is cheap shit no matter where it's made.
8 hours ago, niZmO_Man said:
KYB and your choice of off the shelf springs.
Don't supposed you could link me KYB'a for a 34/GT-T?
KYB part locator wasn't helpful and an eBay/net search gets me as close as an R33.
Im looking into a set of TEIN S lowering springs from the UK instead of the Kings.
You can probably find a set of nismo S-tune shocks and springs for pretty cheap these days.
I run them all round, low-ish, comfortable and stiff enough for twisty roads, you'll feel the limit of them at a track day though but it doesn't sound like that's what you're after so I'd add them to the list of options to consider.
Still achieve the lowered legal limit and be okay handling-wise for what I need?
Might look into this if so!
NB: Teins from the UK we're gonna set me back $300 + $160 postage
Yep Jesse will do springs but can get exxy with shipping because heavy metal
29 minutes ago, Duncan said:
just buy local on this, it's not a top line motorsport application, just a slightly lower car. Kings, Lovells, whoever has them at your local repco....
That'll do the trick on stock shocks for now? I was thinking about springs on stock shocks for a month or two, then fitting some aftermarket shocks (KYB I'm yet to track down for a 34)
for sure, and even KYB is just an OEM replacement.  If you buy a set of specific shocks you will get the springs to match (or vice versa, but the point is they come as a set once they move too far outside standard parameters).
I ran lowered springs on stock shocks then KYBs for years on my 33 GTSt including track days and it was fine for a cheap upgrade. In fact probably better than most $1000-1500 spring and shock sets because they tend to use really cheap shocks and overly hard springs.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
