Leaving your car in reverse gear while rolling down a hill
Hey guys,
Earlier today i turned into a steep hill street and I realised that it was the wrong street so I put it in reverse gear to pull out of the street but then a taxi came up behind me so I couldn't get out of the street. So I went down the hill but after going down about 50 metres I realised I still left it in reverse gear while my foot was pressed down on the clutch pedal. I only realised I left it in reverse gear when I heard that winding noise reverse gear makes so I immediately put it in neutral.
I was wondering if this could damage the gearbox or any transmission system or anything else on the car. I tested reverse gear straight after and it still seemed fine but I just wanted to make sure.
thanks
Edited by IM-32-FK
I'm sure 50m won't cause a problem, but potential issue is that the oil pump is running backwards so no oil pressure in the motor for that time.
Seen as his foot was on the clutch and im guessing the car must have been running (seen as it was being driven prior to this) for a start would not have been an issue.
  • Like 1
I'd like to here your reasoning for this Duncan....how does the oil pump run backwards?  This  - to my thinking - means that the motor was running backwards??
Only way I can think of this happening is if you are rolling backwards down a steep hill while its in say 3rd gear but the motor is switched off??? And if its switched off, no bang or boost so no oil pressure would not be a bad thing given the duration. But willing to learn.
1 hour ago, tridentt150v said:
Nope, not a thing.
Sorry forgot to mention that the front of the car was facing down the hill . I wasn't going down the hill backwards like I was reversing down the hill if u can get the picture
Haha, The engine runs clockwise no matter what gear you are in... Oil pressure would not be effected at all.
If you had of taking your foot off the clutch then best case scenario the engine stalls and you come to a abrupt stop... worst case something may have broken from the shock load..
But you didn't so nothing to worry about at all.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
