Hey guys. I recently put a 3inch dump pipe on my r32. After installing it i took it for a spin. It felt okay. Then i came to a stop and the car revved to 2k. I tried to accelerate but it wouldnt let me go above 2k. It stalled a few times also.
1 of the nuts that connect the dump to the turbo wasnt tightened all the way because i couldnt get to it. Can this be my problem?
No
If a bolt has come loose the worst case scenario will be an exhaust leal. As it is after the turbine there is no power loss from this. I'd expect noise and possibly a tiny tiny power gain from an exhaust leak post turbo if anything
Id say youve disturbed something while doing the dump pipe. Check all plugs and pipes in the area
  • Like 1
just search your symptoms, i couldn't even begin to explain how many times this comes up.
it has nothing to do with your dump but something else you have affected as said.
i just put 2000 rpm into the search, here are 10 of the 1000 which came up.
if you want another 789674653 threads search afm or cas or missfire or limp mode ect
No one knows exactly what is wrong with your car. Stop obsessing about the dump - it is entirely possible that a fault has developed in your car that has nothing to do with your dump. Start reading some of the links that Glynn has kindly provided.
to simplify the subject, a 2000rmp issue is a redflag for very common issues with RB engines. it WILL be the usual suspects. these are very easy to check and fix. the same answers will have arisen in any thread with a 2000rpm missfire/ hesitation.
have a read in the threads about what they found how they found them and how they fixed it.
when i had the issue the solder inside the afm plug had deteriorated, going over bumps gave me my issue, they could have dried ages ago over time and you dislodged it when you took the dump off. check the plugs, maby resolder them... there is a link somewhere... i know i posted one when i hit the issue.
but there is nothing the dump can do within reason to cause the issue your having now. dont look for unicorns when you find horse poo,
Edited by GH05T
  • Like 1
    • With stone chips, you really can't just try to fill them. You really have to sand that spot to lower the edges of the chip, so that the filler will end up covering a wider patch than just the chip. Otherwise, you're trying to have a sharp edged paint surface match up to some filler, and they just do not sand the same and you always end up with a noticable transition. A bunch of adjacent chips should be well sanded back, to round off all those edges, and use a lot (in a relative sense) of filler to raise the whole area back.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
