Oil - RB26
Hi Guys,
After a confusing couple months as a new GTR owner, trying to seek information on the best oil to use for daily (and occasional spirited) driving on a stock as a rock rb26, i ended up with the biggest headf**k of the century.
Basically this is what i got:
Reputable tuner recommendations: Castrol Edge 10w-60
Reputable workshops: Motul x8100 or H-tech 10w-40 (or if you can afford it Nismo oil)
Nissan track enthusiasts: Motul 300v 10w 40
Autobarn: Motul 10w-40, castrol edge 10w-60, Penrite 15w-50 racing
SAU Forums: All of the above + penrite hpr, royal purple, redline etc.... (keep in mind some of these topics were from 10+ years ago, im sure there have been advancements since then)
So i decided to do my own investegation and research on the oils and how they behave in my car.
Firstly i eliminated the motul 300v/nismo oils from the list as it would have limited return on investment, especially if you change your oils every 2500-5000ks, in addition the 300v oils do not have the proper detergents for daily driving, From what i can see i believe the 300v is engineered for track use only.
I decided to try 3 most commonly recommended oils: Castrol edge 10w-60, Motul x8100 and Penrite 15 racing. All 3 oils possess marginal differences in terms of lubrication qualities, espeically with daily driving. Things i tested was oil pressure (normal and spirited driving), oil temperature (25 degree day), engine noise, oil burned.
Here are the results so far:
Motul x8100 10w-40:
Oil temp: 79 degrees normal driving minimal traffic
Oil pressure: 2.2kg idle, 4kg @ crusing speeds
engine noise (once warmed up): ?
Oil burned(end of 5000ks service): None
Castrol edge 10w-60
Oil temp: 81 degrees normal driving
Oil presusre: Same as above
Engine noise: Quieter lifter noise than motul - Viscosity or forumla?
Oil burned: None
Oil pressure: Same as above
Engine Noise: same as Motul
Oil burned: None.
Fuel economy was the same across all oils. I tried keep the tests as consistent as possible, obviously its not the most reliable of tests but it can be used as a good initial reference to newbie GTR owners like myself .. One thing i found strange was that the oil pressure was the same across all brands and viscosity, unless theres some oil pressure regulator system im unaware of ,it is puzzling.. That being said by the end of it, i came to the conclusion that all 3 are good as they provide similar results. I have kept the bottle of the oils i have tested and will probably get some samples professionally tested and post them here to see which oil would be best suited for a rb26.
Edited by Deza3000
Grammar
https://www.sau.com.au/forums/topic/468940-oil-rb26/
There's plenty of information in the current oils thread if you haven't already had a read.
My thoughts are that you can use any group IV oil and buy whichever is on special as some can be nearly double the cost (Motul vs Castrol etc)... I'm skeptical that you would find a major difference between any of the big brands in terms of wear/performance. Fuel economy is going to be similar with most oils, it's not a factor even worth considering as the improvement will be 2-3% at best.
In saying that, I wouldn't mind seeing the tests. But what would you use as an indicator for the 'best' oil?
Edited by owen1r
  • Like 2
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809184
Yep read the forums, everyone has their own opinions and different modifications (i.e. built motor) done to their car, which led me to believe that there is a reason they chose a particular oil brand for their car. That being said, i agree it was all the same anyway.
I used the term "best" very loosely, coming from an evo, most drivers use similar spec oil (10w-40 for street, 50 weight for track), where as the GTR, oil recommendations were very broad, and reading up on oil starvation issues i was getting rather paranoid as to whether i chose the right oil for my car, hence why i went my own way and tested the top 3 recommended oil. Seeing as castrol edge 10w-60 is always on sale, ill probably just opt for that from now on.
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809190
I use Motul 300V and unlike apparently most of you I change it after 20,000km (including track days). I have sent samples for oil analysis and the results have suggested there is no reason to change it more often.
  • Like 2
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809361
I covered the range of scenarios with running Penrite Premium 5 (5W-60) muhuhahaha. But that oil harder to find these days.
I also ran Racing 10 (10W-40), which overheated (twice) on the track. Oil held pressure fine the whole time, so I use Racing 10 now on my Subaru as well (buy a few bottles when on special).
  • Like 1
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809367
Got those oil analysis results by any chance? Wouldn't mind a look.
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809389
This is the only one I can find ATM. When they email them to me I ring them back to get them to explain them to me.
Oil Test 2011.09.28 1000km.PDF
  • Like 2
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809520
Same here but i do mine at 10k ish instead of the 3-5 k change. . And that's also on semi synthetic and not fully :)
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809557
Dessa.
Re your topic on best oil for gtr.
I heve been using nulon ow_40 engine oil in my gtr for some years.found it to be an excellent oil.. no need to top up oil in car. Change oil every 5000 ks
Oil pressure remains constant
Would highly recommend
Cheers
Sent from my SM-G928I using SAU Community mobile app
  • Like 1
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809632
I like that you dont throw away expensive oil that's in good condition. There should be more of this good sense.
  • Like 2
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809778
yes, but "if in doubt, throw it out!"
without doing an oil analysis, it's just guessing. While I appreciate OP's effort to bring some science through looking at oil temp, pressure and lost oil, that is really only scratching the surface. On the other hand, an oil analysis is a hell of a lot cheaper than an unnecessary change of these expensive oils.
BTW, for road use....use anything and change it often. No point spending $100 on oil changes when it's not getting tested at all.
  • Like 2
https://www.sau.com.au/forums/topic/468940-oil-rb26/#findComment-7809782
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
