Help choosing a new turbo.
Hey Everyone,
So as the title says i need some advice on what turbo i should go for my build. the power goal i have in mind is 250-260rwkw. The car is my daily so i am looking for responsive power and as little lag as possible.
The choices i have narrowed it down to so far.
High flowed turbo  R33 or R34 from what i have seen the high flow r33 turbo will get the power levels i want but seems to spool up 500rpm before the r34 turbo.  is the ball bearing char worth getting ? what is the advantage of it ?
Hypergear ATR43SAT , same as high flow is it worth getting a ball bearing char ?
Is there other choices out there for what i want ?? i have looked at a gt3071r but they are on a bit of the expansive side.
https://www.sau.com.au/forums/topic/469150-help-choosing-a-new-turbo/
The simple thing to tell you is that all your questions have already been posted about on here a million times.
The next simplest is to tell you that for your power goal a 21U highflow will be fine.  BB centres make it spool faster (less resistance to spinning up, basically).  ATR43SAT would be somewhat over-rated for your goals.  They can make that little power, but they can make a lot more.
Highflow standard will get you there
This has been answered, and will be answered with similar answers time and time again.
RB25 Turbo Upgrade Dyno Results
https://www.sau.com.au/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/
Hypergear Development Thread
https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/
Read up! :)
Get a good intercooler, many skimp on this and wonder why they hit bottle necks.
If budget is a concern, look at the HDi GT2 FMIC Kits for Skylines. Decent yet budget friendly, although don't expect Plazmaman performance or quality.
My power goal is 250-260kw.
on justjap there is cooling pro inter-coolers, they are very budget from the price i am guessing. I've read mixed reviews about them some people saying they are running fine on high power, others saying the pipes don't line up the best.
I've being looking at a blitz return flow, but also read mixed reviews them being return flow.
what makes HDi or Blitz better then the cooling pro intercooler ??
Edited by ruinned
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
