MAD SKYLINE GARAGE CLEARANCE
Righto, long story short, sold my business and now I have a heap of parts to clear.
SUBSCRIBE for updates cause this post will be regularly updated.
Located in Fairfield NSW, small items can be posted, large items pick up preferable or can freight at a cost.
R34 Cabin Filters - To suit all R34 Models, BRAND NEW aftermarket - $35
R34 GT-R V-Spec Differential - $900
R33 GTS-T S2 Grille M spec - needs mesh (Supercheap Auto has meshes, cut to fit) - $80
R33 GTS/T Series 1 Passenger Side Headlight, good condition - $150
R33 GTS/T Coupe Boot Trims Set - $200
R33 GTS/T Series 2 Front Fog Lights/Indicators - $300
R32 GT-R Parcel Shelf - $100
More to come as I dig through my house.
https://www.sau.com.au/forums/topic/469595-mad-skyline-garage-clearance/
Sucks to not being able to edit top post. Heres more stuff:
R32:
R32 GTS-T/GT-R Rear Windscreen (2 available) - $350
R32 Coupe Door Trims Pair (Suede has been ripped out clean, can use as is or stick on yourself) - $200
R32 GT-R Interior Carpet, Good condition - $250
R32 GTS-T Interior Carpet, Good Condition - $150
R32 GT-R A-Pillar Trims Pair, very good condition - $250
R32 GT-R A-Pillar Trims Pair, 1 side has 3 or 4 broken clips - $150
R33:
R33 Engine Splash Tray (4 available) - $50
R33 GTS-T Full Boot Trim (2 available) - $200
R33 GTS-T/GT-R Boot Slam/Scuff Panel (2 available) - $40
R33 GTS-T M Spec Side Skirts in QM1 Polar White, good condition - $200
R33 GTS/T Midnight Purple Driver Side Guard - $100
R34:
R34 NISMO GT-T Automatic Cluster - $450 (GT-T Models only, may work with HICAS NA's but can't guarantee)
R34 Under engine splash Tray (3 available) - $50
R34 Sedan Side Skirt (LEFT ONLY) - $120
R34 OEM Fog Lights Pair - $200
C34 Stagea Bonnet, Series 2 in black - $250
One Size Fits Most:
New Gates Racing Timing Kit to suit all RB - 4 available - $200 ea.
RB26 Rocker Covers (no coilpack cover or timing cover, powedercoated wrinkle red) - $450 pair
RB25 Raceworks Fuel Rail, new, fitted and removed, never used - $120
RB25 ARP Head Studs 202-4301, NEW SEALED - $250
RB26 ARP Head Studs 202-4207, NEW UNSEALED BOX - $400
Mongoose M20S Alarm System (8 available) - $120
Genuine Nissan PCV Valve Grommet, suits all RB, VQ, SR, CA, VR etc. - $10
Genuine Nissan RB25DET M/T Speedo Gear Cog 32743-30P20 - $20
Genuine Nissan RB25DET M/T Gearbox Yoke Seat 32870-V5003 - $40
Genuine Nissan RB25DET R33 M/T Gearbox Yoke Bush (big type) 32861-01G00 - $20
Genuine Nissan RB25 R33 R34 Gearbox Yoke Bush (small type) 32861-H7301 -  $10
Genuine Nissan R33 R34 M/T Speedo Sensor 25010-21U00 - $200
Genuine Nissan Oil Pump Gasket RB Engines 15066-71L00 - $20
Pro-Torque Rear Main Seal, suits all RB - $35
Permaseal MLSR RB25 Head Gasket    S4413MLSR, new sealed - $250
On 14/03/2017 at 10:08 PM, viper2002 said:
Interested in R34 the under splash tray, do you have the one for the left wheel arch?
Will check and report back
22 hours ago, bawsr33 said:
R34 Cabin filters still for sale ?
yeah i have a heap of these
On 18/03/2017 at 7:57 PM, Exodus01 said:
i  need the stereo surround, its a dark blue color tho, all  the ones ive looked at have been lighter than what i need.. not sure if thats a series difference?
PM  a pic, i'm not aware of any being factory dark blue
I'm interested in the grille but can't seem to find any photos online... do you have a pic you can post up? Would be greatly appreciated
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
