On 8/13/2020 at 3:51 PM, Unzipped Composites said:
I've seen 700rwhp through the stock lines with no signs of being out of flow.
If you put a pressure sensor on the rail it is interesting. Higher than desired base pressure that then drops back to where you want it then potentially drops off is the usual result
You may be able to set 3 bar with engine offf, but when running and pulling vacuum you differential fuel pressure is higher. Not the biggest deal but not great, and makes tuning for big injectors more of a pain.
  • Like 2
7 hours ago, BakemonoRicer said:
If you use a stock fuel system in this I will be so disappointed, basically getting the fuel to the engine for constant HP is critical
In 3rd gear I’ve chopped both an Audi RS5 and C63 AMG, I’m talking several car lengths
you need a fuel system for track work!!!! Put a flex sensor in it then you can run pump and E85!!! But getting a surge tank right is a black art I have all the secrets to get it right
It'll just get what's needed.
No point building a 1000hp fuel system for an engine that will never get there.
Surge tank isn't rocket science either at this power.
Sounds like I might need to budget for lines, I'm not keen on big base pressures.
No engine updates bu the daily got some new tech because Toyota have the most dated interiors ever. Went baller by spending $30 extra to buy a front camera too.
I'm not even sure the space shuttle has a front AND rear cam?!
  • Like 1
Eagerly awaiting future post complaining about fuel surge lol
Another option is to PWM your fuel pump in your surge tank and only fully drive them at 100% DC when you're on boost.
This would reduce the issue of having an undersized return line from your FPR back to tank.
I still think using both your stock lines as a return and running a new 8AN line from your surge to your fuel filter -> rail will solve the inherit issues and also be somewhat cost effective enough.
Another way is to run the FPR at the rear and use both the OEM return and feed as a twin feed to the front only. One small downside to this is your FPR "might" react a touch slower than what your manifold pressure is. If this lag translates to you actually noticing is anyone's guess.
I don't even have an aftermarket FPR currently lol plenty of work to do on fuel system when the time comes, it's an area I really know SFA about.
Current setup is a 2L surge with a 460lph Walbro and a 255lph lift pump in the tank with some braided lines here and there.
  • 3 months later...
Life been busy, engine builder been busy.
Head work nearing completion.
Basic shed nearing completion - maybe today they said, I opted out of being involved after the slab and ditched the original builder who was painful as f**k
Still have water, power and elec, slab clean-up and seal, get hoist etc before I can look at moving my stuff in and doing any real work, will be slow going as it's gonna be too hot for that shit in summer.
  • Like 2
3 hours ago, robbo_rb180 said:
Any more pics of the head work? I've started porting mine but won't going as far as yours has been done
Not really, he only gives me so much as there's some special sauce in the work he reckons. Dunno if it's relevant to your head or did you go P12 as well?
  • Like 1
no fancy ve head just the standard redtop still. Its hard to find info on what works with these heads so just cleaning up little and blending parts. I am aiming to make reliable 250kw (270kw on scramble) as don't want to do gearbox conversion.
For that power, what you're doing well be perfect I reckon.
  • Like 1
We'll see going to get into the standard exhaust manifold after I finish this off.
Have you picked a hoist yet for the shed? I've just ordered a HAPP70 will make working on cars so much better
Funny you mention HAPP, I was looking at HAPP40 or 60 I think it was, something like that.
1900-2000mm lift, clear floor, maybe 300mm extensions if Prado cannot be lifted above my head and still clear the safety (I think it will as Prado is under 1600 cabin height with racks at a guesstimate).
I went solar vents on mine, lots of hot days with no wind. Still too damn hot to work too hard today (shame I have to turn the car around after Bathurst yesterday to the rally next weekend...)
Wind is no issue where I am up on the hill, but from personal experience in my last place, the heat rising tends to make them turn a bit anyway which helps and having multiple 300mm holes in the roof allows the air to escape.
Last shed had a monument coloured roof with thermal break and whirly and it was fine for temps that I'd want to be working anyway. This one has thicker thermal break and a green roof and is higher so hoping it's a little better.
I have contemplated putting an evaporative cooler on this one, but whether it would help or just make it humid AF I dunno. After moving to refrigerative ducted in the house, I'd never go back lol
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
