Ben C34 Posted August 16, 2020 Share Posted August 16, 2020 On 8/13/2020 at 3:51 PM, Unzipped Composites said: I've seen 700rwhp through the stock lines with no signs of being out of flow. If you put a pressure sensor on the rail it is interesting. Higher than desired base pressure that then drops back to where you want it then potentially drops off is the usual result You may be able to set 3 bar with engine offf, but when running and pulling vacuum you differential fuel pressure is higher. Not the biggest deal but not great, and makes tuning for big injectors more of a pain. 2 Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7938315 Share on other sites More sharing options...
No Crust Racing Posted August 16, 2020 Author Share Posted August 16, 2020 7 hours ago, BakemonoRicer said: If you use a stock fuel system in this I will be so disappointed, basically getting the fuel to the engine for constant HP is critical In 3rd gear I’ve chopped both an Audi RS5 and C63 AMG, I’m talking several car lengths you need a fuel system for track work!!!! Put a flex sensor in it then you can run pump and E85!!! But getting a surge tank right is a black art I have all the secrets to get it right It'll just get what's needed. No point building a 1000hp fuel system for an engine that will never get there. Surge tank isn't rocket science either at this power. Sounds like I might need to budget for lines, I'm not keen on big base pressures. Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7938357 Share on other sites More sharing options...
No Crust Racing Posted August 16, 2020 Author Share Posted August 16, 2020 No engine updates bu the daily got some new tech because Toyota have the most dated interiors ever. Went baller by spending $30 extra to buy a front camera too. I'm not even sure the space shuttle has a front AND rear cam?! 1 Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7938393 Share on other sites More sharing options...
BakemonoRicer Posted August 17, 2020 Share Posted August 17, 2020 On 8/16/2020 at 5:28 PM, ActionDan said: It'll just get what's needed. No point building a 1000hp fuel system for an engine that will never get there. Surge tank isn't rocket science either at this power. Sounds like I might need to budget for lines, I'm not keen on big base pressures. Eagerly awaiting future post complaining about fuel surge lol Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7938435 Share on other sites More sharing options...
No Crust Racing Posted August 17, 2020 Author Share Posted August 17, 2020 I'd have to drive it for that ? Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7938439 Share on other sites More sharing options...
Dose Pipe Sutututu Posted August 17, 2020 Share Posted August 17, 2020 Another option is to PWM your fuel pump in your surge tank and only fully drive them at 100% DC when you're on boost. This would reduce the issue of having an undersized return line from your FPR back to tank. I still think using both your stock lines as a return and running a new 8AN line from your surge to your fuel filter -> rail will solve the inherit issues and also be somewhat cost effective enough. Another way is to run the FPR at the rear and use both the OEM return and feed as a twin feed to the front only. One small downside to this is your FPR "might" react a touch slower than what your manifold pressure is. If this lag translates to you actually noticing is anyone's guess. Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7938467 Share on other sites More sharing options...
No Crust Racing Posted August 17, 2020 Author Share Posted August 17, 2020 I don't even have an aftermarket FPR currently lol plenty of work to do on fuel system when the time comes, it's an area I really know SFA about. Current setup is a 2L surge with a 460lph Walbro and a 255lph lift pump in the tank with some braided lines here and there. Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7938469 Share on other sites More sharing options...
Dose Pipe Sutututu Posted August 17, 2020 Share Posted August 17, 2020 Dw cuz your mate habibi here can help 1 Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7938470 Share on other sites More sharing options...
No Crust Racing Posted August 17, 2020 Author Share Posted August 17, 2020 Wouldn't be the first time mate ? Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7938471 Share on other sites More sharing options...
No Crust Racing Posted November 25, 2020 Author Share Posted November 25, 2020 Life been busy, engine builder been busy. Head work nearing completion. Basic shed nearing completion - maybe today they said, I opted out of being involved after the slab and ditched the original builder who was painful as f**k Still have water, power and elec, slab clean-up and seal, get hoist etc before I can look at moving my stuff in and doing any real work, will be slow going as it's gonna be too hot for that shit in summer. 2 Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7943634 Share on other sites More sharing options...
Duncan Posted November 27, 2020 Share Posted November 27, 2020 Shed looks awesome, will be nice to be inside instead of our in the sun over summer Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7943685 Share on other sites More sharing options...
robbo_rb180 Posted November 27, 2020 Share Posted November 27, 2020 Any more pics of the head work? I've started porting mine but won't going as far as yours has been done Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7943700 Share on other sites More sharing options...
No Crust Racing Posted November 28, 2020 Author Share Posted November 28, 2020 Almost there, 2 dead whirlybirds so need to take those back, always something... 1 Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7943705 Share on other sites More sharing options...
No Crust Racing Posted November 28, 2020 Author Share Posted November 28, 2020 3 hours ago, robbo_rb180 said: Any more pics of the head work? I've started porting mine but won't going as far as yours has been done Not really, he only gives me so much as there's some special sauce in the work he reckons. Dunno if it's relevant to your head or did you go P12 as well? 1 Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7943706 Share on other sites More sharing options...
robbo_rb180 Posted November 28, 2020 Share Posted November 28, 2020 no fancy ve head just the standard redtop still. Its hard to find info on what works with these heads so just cleaning up little and blending parts. I am aiming to make reliable 250kw (270kw on scramble) as don't want to do gearbox conversion. Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7943710 Share on other sites More sharing options...
No Crust Racing Posted November 28, 2020 Author Share Posted November 28, 2020 2 hours ago, robbo_rb180 said: no fancy ve head just the standard redtop still. Its hard to find info on what works with these heads so just cleaning up little and blending parts. I am aiming to make reliable 250kw (270kw on scramble) as don't want to do gearbox conversion. For that power, what you're doing well be perfect I reckon. 1 Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7943713 Share on other sites More sharing options...
robbo_rb180 Posted November 28, 2020 Share Posted November 28, 2020 31 minutes ago, ActionDan said: For that power, what you're doing well be perfect I reckon. We'll see going to get into the standard exhaust manifold after I finish this off. Have you picked a hoist yet for the shed? I've just ordered a HAPP70 will make working on cars so much better Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7943715 Share on other sites More sharing options...
No Crust Racing Posted November 28, 2020 Author Share Posted November 28, 2020 Funny you mention HAPP, I was looking at HAPP40 or 60 I think it was, something like that. 1900-2000mm lift, clear floor, maybe 300mm extensions if Prado cannot be lifted above my head and still clear the safety (I think it will as Prado is under 1600 cabin height with racks at a guesstimate). Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7943716 Share on other sites More sharing options...
Duncan Posted November 28, 2020 Share Posted November 28, 2020 I went solar vents on mine, lots of hot days with no wind. Still too damn hot to work too hard today (shame I have to turn the car around after Bathurst yesterday to the rally next weekend...) Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7943717 Share on other sites More sharing options...
No Crust Racing Posted November 28, 2020 Author Share Posted November 28, 2020 Wind is no issue where I am up on the hill, but from personal experience in my last place, the heat rising tends to make them turn a bit anyway which helps and having multiple 300mm holes in the roof allows the air to escape. Last shed had a monument coloured roof with thermal break and whirly and it was fine for temps that I'd want to be working anyway. This one has thicker thermal break and a green roof and is higher so hoping it's a little better. I have contemplated putting an evaporative cooler on this one, but whether it would help or just make it humid AF I dunno. After moving to refrigerative ducted in the house, I'd never go back lol Link to comment https://www.sau.com.au/forums/topic/469678-s13-sprinttime-attack-style-build/page/21/#findComment-7943718 Share on other sites More sharing options...
