Some one ask me what a TD27T looks like in a R32
So some one got a little drunk and made a bet that a TD27T in a skyline wouldn't be sick........
so here's the project so far just because I wanted some were to share my progress ;)
started off with a Hcr32,hicas all removed and swapped out with factory non-hicas lines and subframe, welded diff, as much weight removed as cheaply as possible 700kg chassis as it sits without a motor.
picked up a factory as frig TD27T out of a terrano, 2WD Navara turbo gearbox and a S14 SR20det cross member.
Not sitting in her final resting spot yet. Just waiting on engine mounts to turn up. But hopefully over the long weekend I'll get some more done ;)
  • Like 3
It won't rev like a 20 but if it smokes a set of tires at idle then I'll be happy as a pig in sh*t...
so update : SR20det crossmember with SR20det engine mounts bolts straight into a r32 ( I didn't not know this haha )
td27t with the 4x4 engine mounts bolt up to factory SR20det mountings.... its like Nissan wanted a TD in a Silvia.....
So i have a issue. Between the crank and steering rack I have say 30mm of clearance.
This shouldn't issue me except for the fact the sump is getting cut the f*ck up.
the RWD sump I have not much of it will be left except for the rear section the oil pickup goes in.
If I use the 4x4 sump I'll have the big dropper at the back.
is there a don't make your sump smaller than this guideline?  Or am I just over thinking issues?
ahh, here:  http://www.caradvice.com.au/506503/nissan-australia-secures-future-for-local-manufacturing/
A small Kangaroo cast into the finished product identifies all the components cast in the Australian factory.
I hope this thing is going to go down the path of some of those Euro diesel drift boy setups (Benz, BMW).
Give it a big turbo, 50psi boost and plenty of fuel.  Still won't rev but ought to make enough torque to screw clutches and gearboxes with ease.
Watching with interest.
Edited by Dale FZ1
got given a Garry turbo the other day off a 13b. Exhaust housing is tiny. Intake is a little bigger than A/R 50...
and I'll slap my Nisbro 1 way ARC diff back in once she's road legal ;)
th kangaroo subject is rather interesting.
I forgot to to say why I came back on...
motor all bolted down clutch is on.
Waiting on top mount turbo manifold and intercooler to turn up.... gearbox going in tomorrow.
power steer lines have to be cut.
power steer pump relocation to divers side to suit TD mounts. Lines a lot shorter. Fluid tank moved to battery location.
4x4 sumo clears the rack... needed some encouragement with a 20oz hammer tho.
Starter mould on bell housing extremely close to fire wall... 20oz hammer. Problem solved.
15 hours ago, XRATED said:
This needs a 100hp shot of nitrous/propane mix.
f**k yes......
11 hours ago, Dale FZ1 said:
Amazing what a hammer can fix.
Mate a hammer is the on,y thing that can fix stupidity.
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
