Steve's R33 LM Limited Upkeep
Hi all,
I've been stalking these pages for a quite a long time now. Thought i should throw my car up for everyone to look at.
Some of you will be familiar with this car already as I purchased it from Gav in Perth. Gav had this car built by Glavsport and it has been a no expense spared build.
With that in mind I too have decided to buy things once and any changes that go onto the car will be the highest quality I can reasonably manage. You may be aware that my start with this car was somewhat turbulent as someone tried to steal it from me on the first day I drove it. (See link: Steve's Intro ).
Since then I have hidden the car away under lock and key (and other security measures). The car has just returned to me now from Racepace in Bayswater.
We (well, not really we, more the guys at Racepace) made some changes to my car, repaired the damage from the break in and installed a new immobiliser and tracker. It's nice to have the car back in one piece and using a key to start it, rather than any flat item jammed into what was left of the ignition.
One of the biggest issues I was having was fumes coming into the cabin from under the bonnet/car. It turned out to be a twofold issue.
1. The exhaust was pinched and suffering from E85 damage (it was a 3" mild steel exhaust)
2. The oil catch can breather may have been letting fumes into the air vents for inside the car.
The guys at Racepace have fabricated and installed a brand new 3.5" exhaust with V-Bands and tuned length headers to solve the exhaust problems and they also rerouted the catch can fumes into the rear turbo so they are expelled through the exhaust.
With the new exhaust it was necessary to re-tune the car on the dyno so this was also completed. As someone who doesn't get to drive fast cars much, millions of kWs were deemed unnecessary. I asked the guys specifically if they could turn the engine down to a level it will be happy to perform at for a long, long time.
In tuning the car the guys turned the engine up to what they deemed a reasonable level, then turned it back down as I requested.
The net result of the tuning was:
Full power: 505.4kW (atw) at 27psi
Final Tune: 410kW (atw) at 22psi
I've also got some pictures of the exhaust going in and a dyno run video coming soon.
  • Like 7
https://www.sau.com.au/forums/topic/470372-steves-r33-lm-limited-upkeep/
I can do one better for you:
Made this up when I was feeling enthused one night. It's a one take on my iPhone...
I'll get some more pictures up shortly.
Edit:*** In fact you can still see the fingerprint powder if you look closely.
Edited by Steve85
  • Like 2
I had taken the car to a trackday at Sandown in January.
It turned out to be a 38 degree day, my car managed to turn a full 3 consecutive laps before it began to complain. The car was not revving cleanly in morning and by afternoon was in full misfire mode (even being babied down the straights). I pulled the pin around 2pm and went home.
I had not gotten anywhere near the limit of the tires nor the engine the whole day, which was slightly disappointing.
Racepace have diagnosed that the igniter was not coping with the heat and replaced it for me. Now I have the car back i'll be hoping to go to another day at Sandown to have a real go. So when i was driving it on the road (when is was cool) the car would be fine, but on the track in that heat it just wasn't coping.
I took a friend for a drive the other night, the thing pulls like a monster. I will add that I am convinced the diff gearing is too short. You barely have a chance to think before you need to pull the next gear (yes even 3rd to 4th) Once your in fourth and fifth you have some time, but still not as much as you might think. It also meant gear changes where longer gears would have held down short straights.
Still diff gearing can wait for a while i think.
11 minutes ago, Robzilla32 said:
I saw this beauty when I was picking my car up from RacePace. Very nice indeed.
Thanks! I use every excuse under the sun to visit Racepace instead of calling them on the phone.
So many wonderful cars in such a small place. Gareth always talks me through the work they're doing on each one. I'm like a kid in a giant toy factory...
Steve just to clarify in your original post. The catch can return hose is being re-routed to the rear turbo INTAKE pipe. The idea behind that is that the catch can catches all the oil vapour, but returns the air back to the intake and into your engine (creating a sealed legal system). This also allows the catch can system to be more efficient as well.
Good write up though! You should definitely fill people in on the custom turbo setup and what other goodies you have hidden away!
- Matt from RPM.
  • Like 1
Ahhh... yep. ^This. In my excitement I have gotten this description wrong. I plan to get some more details of the car written in here, just so you all know what hides in the car. And of course, i'll be updating this to reflect any work that is completed on the car to keep it in good condition.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
