I just got a 33.. but because performance. The chassis is better than all the other skylines. the R33 GTR is actually the fastest skyline around the ring.. by 21 secs from R32.. and 28 secs from R34..
R33 gtr 28 seconds faster around the ring than an R34? Where did you get this information from that doesn't sound right.
From the track books? R34 GTR Nur edition ran 8:28 seconds around the ring.. the R32 ran 8:21 secs. The standard are R33 ran 8:01 while the Vspec model ran 7:59 (29 seconds faster). First R35 ran 7:43 with all that new technology, better tyres, double the power just about and 10 years development from the last 33.. Pretty poor effort. 33 remains fastest skyline around the ring and currently holds the fastest drag record too of 7.10 sec 1/4 from a gtst haha
Just seems strange the R34 GTR isn't faster or at least the same as the R33 around the ring. You would think they are nearly identical with the R34 being slightly improved. But yeah after some quick googling the times you posted are right, but i still reckon that the R33 must have had different tyres, running more boost or better driver. 29 seconds is a huge gap.
The r33 was raced.. the r34 was literally a playstation car. Massive improvements made of the 32 because it was still heavily into motorsport whereas the r34 was not. Wasnt at lemans and the only place it did see the track was JGTC.. where it wasnt really a gtr anyway.. I guess they didnt see it needed improvements. As for tyres, they were on OEM tyres and newer tyres just keep getting better and better so the R34 wouldve had better tyres. As i was saying, ill never understand the price tag on the shittest GTR ever built..
On 21/06/2017 at 9:20 AM, niZmO_Man said:
Looks play a big part, but the R34 isn't that big of an upgrade, besides maybe aero. R33 is miles ahead of R32 though.
Going slower isnt an upgrade at all. Its a downgrade. The R34 is a literal downgrade to a 33.
But Paul walker, F&F cult hero status is probably the best answer to why its so expensive.
I'd argue that there is more to cars than how fast they go. I don't think anyone will disagree when I say the 34 interior is miles better than the 33.
And yeah, fast and the furious has a lot to answer for now I can't afford a Supra and a GTR!!!
  • Like 1
Yeah even i wouldnt disagree on that.. that interior is just.. over the top with awesome hahaha still.. worth the extra 70k over a 33? nah.. i dont think it is haha
  • Like 1
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
