r33 rb25 gearbox refurb recomendations
Hey guys,
After discovering I need a new clutch after 6 races at roll racing I have decided I misewell get the box fixed too while its out. Currently it crunches going into 4th due to those 3 clips popping off which were found in an oil change.
Anyone had any personal experience or advice on who to go to in NSW SYDNEY?
So far contacted the following with prices:
-Award diff and gearbox seven hills (awaiting call back)
-Smithfield diff and gearbox - $990
-Gearbox express in ingleburn - 1450
Cheers
Award Diff and Gear are spoken quite well about here. I've not had a gearbox rebuilt, however the turnaround and advice with my Nismo diff they put together for me was fantastic.
They are great on the phone too, give them a bell in the morning :)
cheers guys, ive tried calling award diff and gear and left a message.
Probably hear back from them soon if not give them another buzz.
So far everyone I've talked to has recommended the same. Do you guys happen to know if they do a gearbox pickup/drop off service?
Cheers
@iruvyouskyrine hey mate they charged me the following:
$1100 for standard rebuild (box out of car and delivered to them) - this includes bearings, seals, gaskets, needle rollers, thrust, washers, circlips.
They will inspect once open and give me a full quote before commencing any works such as gears, shafts or hard parts as they put it.
Have read multiple threads stating the strength of a good condition rb25 box is fantastic. I wonder however if its worth upgrading anything else while its open. Currently only have 330rkw but with next turbo setup and cams should be looking at about 450ish. Anyone have advice or suggestions? Box isnt going in for a couple of weeks.
Amayama.com sells new rb25 gearbox for $2100 + postage. Could potentially land a new box in Australia for under $3k
Recondition service usually checks internals and if all good seals it back up. At least with a new box from Nissan all gears/syncros are brand new.
Food for thought...
Food for thought...
New boxes are available through just jap for 3k, in stock, no waiting. Jeez, i sound like a jj marketing dude. Thats the second time i've mentioned them in 24hrs. If there is any hard parts damaged in op's existing box, brand new starts looking attractive.
  • Like 2
Do you get a discount worth passing on? :P
Hmm not a bad idea actually..
just had another chat and they are recomending i upgrade to the newer version of the box to avoid the clip issue again for $1100. Which would bring total to $2200
Originally I was just looking at refurb with possible ppg billet selector fork or plate
New version I assume is what Ive been told can be done  ie: how the r34 box works take a 3rd gear from r34 box and what ever gear changing mechs (I cant remember now) the r34 box uses .... which is not clips and put it in the r33 box to solve the clip issue
No change in strength just gets around the clip issue apparently
Food for thought...
Or buy a box local (Adelaide) from me for around 3k.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
