Loading up a track car
i have a 33gtst i use as my track car (pic below)
The car trailer i have makes it hard to load up as the ramps are to short and the front lip of my car hits when loading...
Its not as easy to put longer ramps on due to the design of the car trailer and how they are stored.
I dont want to make the car higher etc and im sick of putting my shit bumper on to load up
any ideas....? would finding a pair of 20s and chucking on some cheap tyres with a huge tyre profile lift it enough to get it on? finding 20s for a skyline could be tough that fit over evo brembos also
Any other ideas!?
https://www.sau.com.au/forums/topic/471151-loading-up-a-track-car/
A lot of people I've seen just remove the front bar in this situation, using Dzus fasteners or similar to make it quick and easy.
Otherwise, could try carrying blocks of wood around to help at the start of the ramp.
I feel like 20's with high profile will certainly have massive clearance/rubbing issues
I've got timber for my driveway. You have to reinforce it where it is lowest, and shave the ends so they sit flush against the two ends but they work well. And cost a grand total of $14 and one hour.
I should add we also used them for loading and unloading my car onto a trailer. Exactly as described above.
the easiest way to improve both the angle of the ground to ramps and ramps to bed of the trailer (where sometimes zorst scrapes) is to raise the rear of the tow car on caravan leveller/ramps or similar.  I've seen the same trick with a jack under the towball but I think that puts a hell of a lot of weight on a jack...
And if that's not enough go the blocks of wood suggested above at the start of the ramp, you can even have them flat on the ground as long as they are lower than the distance of splitter to ground on the car.
And if you can work out how to do it, long ramps are the real answer.  About twice what a normal trailer allows for is lovely.
  • Like 2
My car has a splitter on it and removing and re-attaching is a pain, I made 2 stage ramps with some handles from pine sleepers. They just sit on the trailer behind/in front of the car and are held on with tie downs.
Ghetto as but works and was cheap.
I could only find these 2 photos quickly and added one of the Silvia to show the splitter height. GTR clears it too.
The length was determined by how long needed to hit wheel before splitter edge hits timber.
I also have some of those little plastic Cusco ones that allow you to get just enough height to get a jack under it which is enough for people.
  • Like 1
I'd like to make a V2 that's lighter or I did consider running a drill through them to take core sections out but was worried about them cracking and splitting.
I am not a great builder/fabricator and have limited power tools so this was "easy" for me to do.
I've seen layers of ply screwerd together and then cut at one angle so there's no "steps" like mine. Would could be a better idea?
I have the same problem. I use the car ramp approach too. Back the rear of the truck onto the ramps to dip the trailer then a small plank that sits under the trailer ramps that the front wheels lift up on before the main ramp to help the nose clear.
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
